Local Time 12:19 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about HDMI resolution
Frank N. Furter
Posted: 08:58am 30 Jan 2025
Hi to all!
Can anyone tell me what the maximum resolution is with PicoMiteHDMIUSB for two colors and black?
Is that 640x480 or can something higher be set?
Frank
Posted: 09:16am 30 Jan 2025
option resolution 1280x720 in mode 1
Gives 1280x720 pixels black and white, with color tile support.
See user manual page 30
Edited 2025-01-30 19:24 by Volhout
Frank N. Furter
Posted: 09:28am 30 Jan 2025
I would like to display any lines in two colors on a black background. This will not be possible with TILE???
Frank
Posted: 09:39am 30 Jan 2025
640x480 mode 3
Frank N. Furter
Posted: 09:49am 30 Jan 2025
Ok, thanks!
Frank
stanleyella
Posted: 01:21pm 30 Jan 2025
If I use higher hdmi resolution the cpu speed is higher. Does that mean my code will run faster in higher res? stan
Posted: 01:47pm 30 Jan 2025
If your code depends on any MMBasic timing such as TIMER or SETTICK then no. Those timers stay at their correct values.
Also, if your code is writing to the screen then there are more pixels to write in higher resolution. So your CPU is running faster but your video is running slower. :)
