apalert Regular Member Joined: 06/07/2023 Location: AustraliaPosts: 47
Posted: 09:53am 04 Jan 2025
Struggling to get channel B working on a pico. Wanting to use pin 12 which is PWM4B. In the following code, entered at the console prompt, pin 11, which is PWM4A, works fine. Pin 12 I come to grief!
> setpin 11, pwm > pwm 4, 100, 50 > pwm 4, off > > setpin 12, pwm > pwm 4, 100, 50 Error : Pin not set for PWM > pwm 4b, 100, 50 Error : Expression syntax >
Appreciate if someone can put me out of my misery :)
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11882
Posted: 09:59am 04 Jan 2025
From the manual
So if I don't want dutyA but do want dutyB it becomes
PWM channel, frequency,,dutyB[,phase][,defer]
Posted: 10:23am 04 Jan 2025
Awesome, thanks Peter I did read manual I promise, just too dense to figure it out! Your example was a great help.
Canada_Cold Regular Member Joined: 11/01/2020 Location: CanadaPosts: 57
Posted: 11:46am 04 Jan 2025
apalert,
I worked on a project last fall that required a PWM output. I found the following post Very helpful.
"PWM out, need some examples, not working for me."
