Forum Index : Microcontroller and PC projects : 2.2" TFT
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2054 |
I was looking for a 2.2" display and bought one of these Display On a MM backpack it sits a bit offset but all I get is the backlight. Can any one point me to a 2.2" display that works. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3429 |
It isn't clear what chip is on the display. All I can suggest is look for one that only shows ILI9341. The photo in the add shows a regulator U1 with a bypass jumper J1. Check that you have 5V in and 3.3V out if J1 is open. If your supply is 3.3v bridge J1. |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1162 |
If you are powering VCC at 3.3V you should bridge J1 to bypass the regulator. It appears to be one that should work. Did you try GUI TEST LCDPANEL to verify it does not have just have colours inverted. P.S. What he said. Edited 2024-12-30 17:53 by disco4now F4 H7FotSF4xGT |
Running at 5v. I took the 2.4" screen off a working project and when I connected this one all I get is a back light. Didn't do a GUI test touch, I'll do it tomorrow. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
That is GUI TEST LCDPANEL , there is no touch on those 2.2" screens. F4 H7FotSF4xGT |
Yes I meant LCDPANEL, I know it doesn't have touch. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
