Local Time 13:40 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite VGA Text vs Print @
Mark
Posted: 12:44am 29 Dec 2024
When working with text is there an advantage/preference to using Text or Print @?
Here's what I've seen
Print will print numbers with a default format.
Print can print with default coordinates (from a previous Print or Text command).
Mark
Posted: 01:13am 29 Dec 2024
The main use for Print@ is to position text on the console screen.
For an attached screen Text is usually the better option.
If you use OPTION LCDPANEL NOCONSOLE you can then have different displays on the two screens as Print@ will then only go to the console while Text only goes to the attached screen.
Edit.
The word LCDPANEL also applies to the VGA screen.
Edited 2024-12-29 14:19 by phil99
Mark
Posted: 01:14pm 29 Dec 2024
