Local Time 13:13 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM* constants
Mark
Posted: 03:42pm 27 Dec 2024
If a program accesses a MM.* (i.e. MM.FONTWIDTH) or MM.Info(*) constant many times, is execution faster if the value is stored in a program constant (i.e. const fw% = MM.FONTWIDTH) and access that constant.
Also, is accessing a constant any faster than a variable?
stanleyella
Posted: 05:22pm 27 Dec 2024
good point, mm.screen width/height checking
Posted: 08:21pm 27 Dec 2024
Read only variables (ie, MM.HRES) are generally implemented the same as a built in function (ie, COS()).  This means that it is converted to a one or two byte token which the interpreter uses to index into a table of addresses for each function.  This is very efficient and will return the value with a minimum of CPU cycles.
Constants on the other hand are implemented as ordinary variables except that they have a read only flag set.  Getting the value of one of these involves either looking up a hashed table or searching through a list of values, and that takes many CPU cycles.
So, read only variables are more efficient BUT you should not be over concerned with trying to make the interpreter more efficient.  Your choice of the program logic and algorithms will have a far greater impact on the speed of your program.
Edited 2024-12-28 06:24 by Geoffg
Mark
Posted: 09:28pm 27 Dec 2024
stanleyella
Posted: 09:35pm 27 Dec 2024
so. if I used v_ht=mm.vres:h_wid=mm.hres then any gains? looping and testing
Posted: 10:53pm 27 Dec 2024
> clear
> dim integer n,x,y : dim float t,tt
> t=timer:for n=0 to 999999:x=mm.hres:y=mm.vres:next :tt=timer-t:? tt
49708.761
> const h=mm.hres, v=mm.vres
> t=timer:for n=0 to 999999:x=h:y=v:next :tt=timer-t:? tt
55729.417
Saves about 6µS per loop using MM.* rather than Const.
Therefore follow Geoff's advice.
Edit.
That was Pico1 at 126MHz, at 378MHz the saving is just 2µS per loop.
Edited 2024-12-28 09:02 by phil99
Posted: 11:03pm 27 Dec 2024
  stanleyella said  so. if I used v_ht=mm.vres:h_wid=mm.hres then any gains? looping and testing
Following Geoff's post, will be slower.  But not much.
