Local Time 10:00 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mp3 player
stanleyella
Posted: 10:21pm 26 Dec 2024
anyone used this device for sound out as alternative to filter circuit?
https://www.aliexpress.com/item/1005007240103433.html?pdp_npi=4%40dis%21GBP%215.10%210.80%21%21%216.27%210.98%21%402101646317317673356745769d10c8%2112000039917955536%21affd%21%21%21&dp=CjwKCAiAmrS7BhBJEiwAei59i7yRKd1RM5E1JWil_pHVeBJ1gUCVegRf3zX3ccgRdTWZCFZcLvE5vBoClM0QAvD_BwE%7C0AAAAAC5ena3FXAKD8ShAEgZpnn2URfFYM%7CCj4KCAiA9667BhA4Ei4Ar11gnoMxdTMEE133MyF-JBfLCRks67bKKfVgL_AMyHo5y55kDSlOWNHuRJakGgIgKg%7Cv1&aff_fcid=78ba27af7b654d2b85b3eda377dd2680-1735251311340-09716&aff_fsk&aff_platform=api-new-product-query&sk&aff_trace_key=78ba27af7b654d2b85b3eda377dd2680-1735251311340-09716&terminal_id=84cb6456fbbb40b5af37b158c6c66799&afSmartRedirect=y
or anything and what/where is the codec and how to load it. regards, stan.
Posted: 10:33pm 26 Dec 2024
I've used a couple of different VS1053 boards and they were both fine. MMBasic doesn't support audio input though, so the MIC input doesn't work. It does support VS1053 as an output device.
The audio output is NOT common to GND, it's designed for headphones only. There is a way round this.
Sound quality is good.
If you are trying to get a line output without filter components then this module is not for you. Try the DAC chip instead, that can use a simple RC filter but there is still DC on the output that may need a further capacitor and bleed resistor.
Edited 2024-12-27 08:54 by Mixtel90
stanleyella
Posted: 11:00pm 26 Dec 2024
so it does the same as the filter but plays mp3 as well? what's the codec about. is it in the device or a file to load? sorry thick. will I have the pins using hdmi usb? pins left spi. cheers.
can I use the sd card reader as a normal sd card reader, that would be great, worth the board price alone.
Edited 2024-12-27 09:15 by stanleyella
Posted: 11:03pm 26 Dec 2024
It's documented in the manual.
OPTION AUDIO VS1053 ...
Needs quite a lot of pins that you can't share with anything else. The "codec" is firmware in the VS1053. It has several codecs for different types of audio.
stanleyella
Posted: 12:30am 27 Dec 2024
maybe if I didn't use option sd card and option audio then the card could use those pins and do audio and sdcard
Bill.b
Posted: 06:02am 27 Dec 2024
Depending on what you want the audio for, I use a DFPlayer MP3 to play selected tracks on the SD card in the player.  Below is the program for a Christmas  train use in my lights display.  The track consist of several stream train sounds that can be selected by the program.
'xmas Train control for the picomite
'28/01/2024
'Bill Brown
Option colourcode on
Option autorun on
Option DEFAULT NONE
Dim  aa$
Dim integer c(4),x,y,z,Tspeed,loop1
dim integer CMD1,arg
dim integer manloop
SetPin GP22, Dout
setpin gp5, dout  'Light
setpin gp6, dout  'smoke
setpin gp14, din   ' local start
setpin gp15, din   'hall effect switch - Station Stop
SetPin GP12, pwm6A  'Forward contol  PWM output
pin(gp7) = 1
SetPin GP21, Gp20, com2   'sound output
Open "com2:9600" As  #2
cmd1 = &h09   'Set SD card
arg = 0002
send
cmd1 = &h06  'Set volume
arg = 30
send
 if pin(GP14) = 0 then
   TrainFWD
 end if
Loop
  '****************Train Forward *******************
  sub TrainFWD
    pin(GP6) = 1
    pin(GP5) = 1
   cmd1 = &h12   'Play 0004.mp3 rain Starting
   arg = 0004
   send
 for loop1 = 10 to 100
   PWM 6,500,loop1  'pwm output to motor FWD
   pause 150
 next loop1
  cmd1 = &h12   'Play 0001.mp3
  arg = 0001
  send
  do
   loop until pin(GP15) = 0
   pause 5000
  station
  end sub
  '************************** Stop  Train ************************
  Sub stoptrain
     for loop1 = 90 to 10 step -1
        pause 20
     next loop1
     PWM 6, 500,0
   cmd1 = &h12   'Play 0002.mp3  Train Stopped At station
   arg = 0002
   send
  end sub
  sub Station
  manloop = 1
   stoptrain
   do
    manloop = manloop + 1
     pause 100
   loop until manloop > 150
  TrainFWD
  end sub
'-------------------send to mp3 module ---------------------------
sub send
print #2, Chr$(&h7E) + Chr$(&hFF) + Chr$(&h06) + Chr$(cmd1) + Chr$(0) + Chr$(0) + Chr$(arg) + Chr$(&hEF);
pause 100
arg = 0
end sub
Bill.b
'28/01/2024
'Bill Brown
Option autorun on
Option DEFAULT NONE
Dim  aa$
dim integer manloop
SetPin GP22, Dout
pin(gp7) = 1
arg = 0002
send
arg = 30
send
   TrainFWD
 end if
Loop
  sub TrainFWD
    pin(GP6) = 1
    pin(GP5) = 1
   arg = 0004
   send
   pause 150
 next loop1
  arg = 0001
  send
  do
   pause 5000
  station
  end sub
  Sub stoptrain
        pause 20
     next loop1
     PWM 6, 500,0
   arg = 0002
   send
  end sub
  sub Station
  manloop = 1
   stoptrain
   do
     pause 100
  TrainFWD
  end sub
sub send
pause 100
arg = 0
end sub
Bill.b
Posted: 06:07am 27 Dec 2024
ooops  must have hit the post button twice .
Posted: 08:35am 27 Dec 2024
A lower pin count alternative is to use a Pico 2 in combination with a DAC. Pico 2 supports PLAY MP3 and the output from the DAC doesn't need much filtering (RC then an isolating cap and anti-thump bleeder resistor). The DAC needs 3 SPI pins, CS, SCK and MOSI (the MISO pin isn't used).
stanleyella
Posted: 02:22pm 27 Dec 2024
"Pico 2 supports PLAY MP3". without extra hardware? will try a mp3 file.
Posted: 02:34pm 27 Dec 2024
It's still PWM output so you should use the usual filter, but otherwise yes - it can do the MP3 decoding.
stanleyella
Posted: 03:23pm 27 Dec 2024
I get an error
B:
> FILES
B:/
  <DIR>  SYSTEM
01:37 01-01-2000          0  bootcount
19:26 01-08-2024      68506  RISsound.mod
16:48 30-08-2024      44556  sfx-bg.mod
22:39 29-03-2023   55342378  t1.wav
21:11 02-04-2023   65642368  t2.wav
23:05 09-04-2023          0  t3.mp3
22:03 09-04-2023   22763937  t4.flac
1 directory, 7 files
> PLAY MP3 "t3"
Error : Mp3 init
stanleyella
Posted: 04:19pm 27 Dec 2024
@Bill.b, I got a sd card mp3 player from picaxe. works with arduino, serial.
it was gonna be a "robot vehicle face" with voice from Audacity
https://www.youtube.com/watch?v=4LnerMCgeNU
I couldn't play an mp3 file
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.01RC4
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD UK, 0, 0, 600, 150
OPTION CPUSPEED (KHz) 315000
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
Posted: 04:21pm 27 Dec 2024
  Quote  I get an error
B:
> FILES
B:/
 <DIR>  SYSTEM
> PLAY MP3 "t3"
Error : Mp3 init
I wonder why? How big is the file t3.mp3? Could that be the issue?
stanleyella
Posted: 04:55pm 27 Dec 2024
Yes boss you right, I didn't see it was duff file
these work, sound fine, nice feature pico 2
thanks
> b:
> files
B:/
19:05 28-07-2020    8802830  adele,tupac,eminem.mp3
21:07 29-09-2024   67081508  adele,tupac,eminem.wav
17:38 28-07-2020    8444268  Biggie,Adele,Tupac.mp3
21:08 29-09-2024   65642084  Biggie,Adele,Tupac.wav
22:16 28-07-2020    5338459  biggie.johnny cash.mp3
21:08 29-09-2024   39577644  biggie.johnny cash.wav
22:54 23-09-2024     138982  fatlib.bmp
20:35 20-03-2020   49501189  THENOT~1.MP3
21:11 29-09-2024  363818330  THENOT~1.WAV
18:49 28-07-2020    7598885  tupac,eminem.mp3
21:11 29-09-2024   54718580  tupac,eminem.wav
0 directories, 12 files
> play mp3 "tupac,eminem"
stanleyella
Posted: 10:24pm 27 Dec 2024
in the "manual" the differences between 2040 and 2350 like you can play mp3 with 2350 and the other differences should be mentioned if not already but the manual is not finalised yet.
Posted: 10:49pm 27 Dec 2024
They are mentioned, but you have to read the whole manual. The Pico and Pico2, including the Webmite etc. are all in the same manual. It would be silly to try to point out every single change that has been made on every platform. :)
Note that you can play MP3s whether you have a RP2350 or not.
Page 133
PLAY MP3 file$ [, interrupt]
Will play a MP3 file on the sound output (RP2350 ONLY).
'file$' is the MP3file to play (the extension of .mp3 will be appended if
missing). The sample rate can be up to 48kHz.
The MP3 file is played in the background. 'interrupt' is optional and is the
name of a subroutine which will be called when the file has finished playing.
If file$ is a directory the Pico will play all of the files in that directory in turn.
Page 134
VS1053 specific PLAY commands
Will play a MP3 file on the sound output.
'file$' is the MP3 file to play (the extension of .mp3 will be appended if
missing). The sample rate should be 44100Hz stereo.
Edited 2024-12-28 08:51 by Mixtel90
stanleyella
Posted: 12:49am 28 Dec 2024
the fact that 2350 pico 2 plays mp3 files as is... with filter is good, I was gonna buy device but no need. that's pretty cool. and the pico 2 does hdmi and 2040 don't. sort of slipped under the radar. we don't want everyone upgrading. I got 4 pico 2's
Bill.b
Posted: 03:31am 28 Dec 2024
The MP3 player i use is the same as the one supplied by picaxe and plays the MP3
files OK.  They need to be in a MP3 sub directory on the sd card and numbered 001 to 999.mp3
Posted: 08:34am 28 Dec 2024
What you use depends on what you want:
Pico 2 - most CPU load as the decoding is done in firmware. The Pico 2 is efficient though, which is what makes it possible on this chip.
VS1053 - decoding is fast and you gain other things (like MIDI), but SPI adds an appreciable CPU load. Probably not too bad a load on a Pico 2 though.
Hardware module - a little restricted in what it can do, but has zero CPU load
There is no right way for all cases.
