Local Time 13:26 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : XBox gamepad
karlelch
Posted: 12:37pm 26 Dec 2024
Hi Peter
First of all, the code on GitHub is now organized really well - I was able to compile MMBasic successfully out of the box! Thanks!!
I was testing the XBox gamepad with PicoMite MMBasic USB RP2350A Edition V6.00.01RC10, with the following options:
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION CPUSPEED  150000 'KHz
OPTION DISPLAY 64, 80
The gamepad (EasySMX Wireless) was not recognized any longer and therefore I looked into `USBKeyboard.c`. I don't think the issue is in the MMBasic code - therefore I did not trace back when it stopped working through the earlier versions. I think it may be related to a change in TinyUSB (?). In any case, my gamepad got "stuck" in PS3 mode without working correctly as a PS3 controller, and I could not change the mode on the controller.
I checked what is happening when I plug in my controller and it seems to cycle through different modes before "settling" into the correct mode:
> XBox Controller Connected on channel 3 (pid=&H2009, vid=&H57E)
> XBox Controller Disconnected
> XBox Controller Connected on channel 3 (pid=&H48, vid=&H2F24)
> XBox Controller Connected on channel 3 (pid=&H5500, vid=&H11C0)
Then it works as before.
To make MMBasic deal with this mode change, two lines need to be added to "USBKeyboard.c". In case you consider this change; I made a pull request on GitHub.
Best
Thomas
