Local Time 13:26 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic SetTick vs INPUT
Mark
Posted: 11:01pm 24 Dec 2024
It appears that during the MMBasic INPUT processing, SetTick interrupts are disabled (or at least they aren't working for me ).
I wrote a program that on a SetTick interrupt updates a time display at the bottom right of the screen, but while in the INPUT routine, the time isn't being updated.
Mark
Posted: 11:18pm 24 Dec 2024
From the manual
page 47
Interrupts
  Quote  Interrupts are only checked by MMBasic at the completion of each command, and they are not latched by
the hardware. This means that an interrupt that lasts for a short time can be missed, especially when the
program is executing commands that take some time to execute. Most commands will execute in under
15μs however some commands such as the TEMPR() function can take up to 200ms so it is possible for
an interrupt to occur and vanish within this window and thus not be recognised.
Mark
Posted: 01:51am 25 Dec 2024
Thanks.  I suspect that the INPUT command lasts until the user hits ENTER so it certainly will miss interrupts. I have my updated timer sort of working using INKEY$. The problem is getting an underscore cursor to display.
Mark
Posted: 08:36am 25 Dec 2024
Cheat! Blank it during input. :)
twofingers
Posted: 11:43am 25 Dec 2024
  Mark said  ... I have my updated timer sort of working using INKEY$. The problem is getting an underscore cursor to display.
Mark
Why don't you write your own function for this? Similar to this.
Kind regards
Michael
The lone and ...
