Forum Index : Microcontroller and PC projects : Pico/Wembite User manual in docx available?
| stef123 Senior Member Joined: 25/09/2024 Location: United KingdomPosts: 105 |
Hi, the reason why i am asking for this - i´d like to feed an LLM/Vector Database with the Informations given in the User Manual, but extracting them from the PDFs leads into a bit of a mess, because the solid line which separates the commands from their explanation sometimes destroys the connection between them when converting from PDF. My goal is that the LLM should be able to create Pico/Webmite programs, but i know that it is not simply done by pushing a manual into the Vector Database, i will need to perform several adjustments on how and when to use the commands, but for that i also i need a good base to work with. Its just a try and no guarantee that it will work at all. Many thanks! Best regards Stef |
You heathen. ;) DOCX is a scrambled and seriously damaged format courtesy of Microsoft. Embrace, Extend, Extinguish! If anyone has one it will be Geoff, but whether he'll be willing to release it for this purpose I don't know. It is copyright material after all. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
Hi, why not RTF? Geoff will decide Geoff's matter himself. Finally, there is the option to export the PDF into an editable format. Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
I see Microsoft are removing Wordpad from Windows. It appears that they want to get people off RTF. They'll get my RTF editor (Jarte) out of my cold, dead hands - it's better than Wordpad. :) Wordpad is clever. It can attempt to open anything - including AutoCAD DWG files. It will show which version of the DWG format the file is in, even though it can't display the drawing. IMHO getting rid of it is a serious mistake. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Interesting, I'll take a look at "Jarte". ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Yup, already tried this with Calibre, but the outcome is not very usable. The Key problem is the line (and sometimes the commands which span over two pages) i had mentioned, it sometimes tends to produce garbage. I am in the process to do it all manually - after some automatic approaches by using self-written programs also failed - not totally, but a lot of work has to be done by hand anyway and thats what i wanted to avoid. As you probably know, LLMs / Vector Databases require a quite clean source to work with. |
Stef, I'm happy to send to you the new manual's source (ie, docx) when it is released. Send me an email (projects@geoffg.net) with your address. Geoff Geoff Graham - http://geoffg.net |
