Forum Index : Microcontroller and PC projects : PM VGA USB - latest version?
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043 |
Hi all. ![]() I've been a little out of date with things for the last couple of months, so can someone here let me know if I have the latest FW for the all-in-one PCB that Peter(matherp) designed - CMM1.5 Currently, it is running version 5.09 Is this still the latest? I want to play with an idea over the Christmas holidays using the CMM1.5 board, but it would be good to know I am using the latest FW before I start. Smoke makes things work. When the smoke gets out, it stops! |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
v6.00.01RC5 |
Ta, thanks muchly. Smoke makes things work. When the smoke gets out, it stops! |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11882 |
Remember just OPTION RESET CMM1.5 to configure |
Acknowledged. ![]() Smoke makes things work. When the smoke gets out, it stops! |
