Local Time 10:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : syntax checker modfies comments
andreas
Posted: 06:15pm 04 Dec 2024
Hello,
if I write this program into the editor:
' from a => b
and I save this, then I get after reopening the code this:
' from a >= b
So the syntax checker "corrects" my comments, but everything written after a comment ' should be unchanged, isn't it?
WebMite MMBasic RP2350A Edition V6.00.01RC1
-andreas
Edited 2024-12-05 04:18 by andreas
twofingers
Posted: 06:57pm 04 Dec 2024
  andreas said  ... So the syntax checker "corrects" my comments, ...
There are more:
' a$=MM.INFO$(flash)
0 = 1
a$=MM.INFO$(flash)
maybe we'll find even more.
But I think Peter knows the phenomenon, so don't get excited.
If we had a list of more examples we could evaluate whether there is a problem.
Kind regards
Michael
Posted: 07:20pm 04 Dec 2024
Can probably fix it
Posted: 03:20am 05 Dec 2024
This is strange, it looks as if the conversion from => to >= is being done in the preprocessor before it realises that it is a comment.
Edited 2024-12-05 13:26 by Geoffg
Posted: 08:26am 05 Dec 2024
It is, have fixed in my dev version including in multi-line and REM statements
Edited 2024-12-05 18:26 by matherp
andreas
Posted: 06:19am 06 Dec 2024
How do you manage it to read all these many postings and be productive in programming at the same time?
many thanks!
-andreas
