Local Time 10:32 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite 6 RC15: AUTORUN ON in a library?
PhenixRising
Posted: 02:17pm 14 Nov 2024
I put my entire program in a library, power-up and I get the command prompt. Autorun apparently ignored.
Is there an elegant workaround?
Posted: 02:52pm 14 Nov 2024
Maybe MM.STARTUP
Or another tiny program that invokes the ibrary.
PhenixRising
Posted: 03:35pm 14 Nov 2024
  JohnS said  Maybe MM.STARTUP
Cheers John
I stuck a label "initRT" at the top and then my autorun program:
Goto initRT
Actually, this had me scratching my head; I had my program in the library and then downloaded a completely different program using MMC. The new program downloaded but the program that executed was the one in the library. Took me minute
Loving this library, feature, though
PhenixRising
Posted: 04:39pm 14 Nov 2024
Update: If the main program is blank, OPTION AUTORUN gets turned off but even if the main program has only a remark, OPTION AUTORUN ON is preserved and my program in the library runs.
I don't need any commands, just non-blank.
Posted: 05:09pm 14 Nov 2024
That makes sense. The library is an extension of the main program.
Posted: 05:22pm 14 Nov 2024
You have to think laterally. The Library is no longer a flash slot and doesn't follow the same system.
You can make something in the Library run automatically using a SUB called MM.STARTUP but it runs *before* the main program. It isn't the main program and you can't use AUTORUN on that slot.
If you want a program to run automatically and you have a Library installed you can use AUTORUN on flash slot 1 or flash slot 2. that's all. Without a library you can use flash slot 3 as well.
PhenixRising
Posted: 05:39pm 14 Nov 2024
It's actually worked out perfectly
My library code is running the PID and motion profiling in a 1ms SETTICK. I stop the program and type EDIT and all I see is:
function main()
end function
This is where other control logic gets inserted. very clean
Edited 2024-11-15 03:40 by PhenixRising
Posted: 05:54pm 14 Nov 2024
The Library is actually an extension of the user program area to all intents and purposes. It's just that it's routines aren't displayed when the program is listed. Any routines that you could have in the program area will also work if you transfer them into the Library.
However, you can't edit programs in the Library directly. Neither can you delete them, you can only delete the entire library. It's good to keep a file of your Library routines that you can use for editing and reloading.
