Local Time 10:32 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Delighted with RP2350 @300MHz
PhenixRising
Posted: 11:06am 07 Nov 2024
I am not sure if the Pin(Temp) is something that we can rely on (?) but the value sits at ~17C. If I kick it up to 315MHz, the temp increases to ~21C
These temps are pretty low, right?
From the datasheet:
  Quote  2.3. Recommended operating conditions
Operating conditions for the Raspberry Pi Pico are largely a function of the operating conditions specified by its components.
Operating Temp Max 85°C (including self-heating)
Operating Temp Min -20°C
VBUS 5V ± 10%.
VSYS Min 1.8V
VSYS Max 5.5V
Note that VBUS and VSYS current will depend on use-case, some examples are given in the next section.
Recommended maximum ambient temperature of operation is 70°C.
300MHz is perfect for my needs
Edited 2024-11-07 21:11 by PhenixRising
Posted: 11:26am 07 Nov 2024
From the RP2040 Datasheet
4.9.4. Temperature Sensor
The temperature sensor measures the Vbe voltage of a biased bipolar diode, connected to the fifth ADC channel
(AINSEL=4). Typically, Vbe = 0.706V at 27 degrees C, with a slope of -1.721mV per degree. Therefore the temperature
can be approximated as follows:
T = 27 - (ADC_voltage - 0.706)/0.001721
As the Vbe and the Vbe slope can vary over the temperature range, and from device to device, some user calibration
may be required if accurate measurements are required.
The temperature sensor’s bias source must be enabled before use, via CS.TS_EN. This increases current consumption
