Local Time 10:42 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "DEVICE LCD INIT" - command unknown
stef123
Posted: 04:31pm 03 Nov 2024
currently i´m fiddling around with a HD44780 20x4 Display - has been used dozens of times in other projects - but PicoMite (V5.07) complains with
DEVICE LCD INIT GP12, GP13, GP14, GP15, GP10, GP11
Error : Unknown command
in both running in a program or directly in command line mode.
So i suppose this command has been removed as being said by the PM, but whats the alternative Init command for 44780 in 4 Bit mode and which are the commands for entering Text - by the "Text"-Command, like with GLCD-ModuleS?
Best regards
Stef
Edited 2024-11-04 02:33 by stef123
stef123
Posted: 05:22pm 03 Nov 2024
Solved by using V5.08, sorry for the fuss.
