Local Time 10:42 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : option web messages
ville56
Posted: 08:06am 01 Nov 2024
I try to get rid of the NTP messages on the console which occurs every time the WEB NTP command executes.
"option web messages off" does not help, it even does not show up in "option list" as set. Is there any other option which i should enable or is this message not suppressible?
Regards, Gerald
73 de OE1HGA, Gerald
ville56
Posted: 08:07am 01 Nov 2024
sorry ... finger too fast
WebMite MMBasic Version 6.00.00RC11
Posted: 08:22am 01 Nov 2024
I'm not sure about this at all. Isn't it supposed to work like that? All error messages etc. go to the console as the user isn't intended to see them. They can optionally appear on a connected display, I think. I'm only guessing, but isn't this an information message that you'd expect on the console but may not want on a display?
ville56
Posted: 10:10am 01 Nov 2024
I'm d'accord as long as we talk about error messages. But the message i want to get rid of is:
ntp address 192.168.0.254
got ntp response: 01/11/2024 11:01:43
which for me is an informational message and that is going to disrupt whatever is displayed on the console in the normal program flow. I just didn't want to look for a workaround .... particularly as there is this option web messages off ....
Posted: 10:28am 01 Nov 2024
My point is that the user shouldn't be seeing the console on a Webmite. The user sees the info on a browser, LCD display or whatever. It doesn't matter whether system messages on the console are informational or errors as only the developer or system monitor will see them. You don't really want to suppress them. In fact, in many (probably most) cases there will be nothing connected to the console connection.
As I said though, I'm unsure on this answer and I don't have enough experience with the Webmite to give an accurate answer to your question. :)
Posted: 10:33am 01 Nov 2024
Don't know what version you are running but OPTION WEB MESSAGES OFF works for me (V6.00.00RC12). This command is temporary and should be included in a program
Edited 2024-11-01 20:34 by matherp
ville56
Posted: 10:35am 01 Nov 2024
Thanks for your input and sure, you are basically right with your opinion. I'll think about that more deeply to find a proper solution. Sometimes i'm thinking too complicated ....
