Local Time 14:34 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : servo
georgestheking
Posted: 06:28pm 31 Oct 2024
I want to use servo on picomite.
I use the cytron maker board.
I understand that the syntax are :
PWM 6,50,chA,5+servo1*.25
PWM 6,50,chB,5+servo2*.25
PWM 7,50,chA,5+servo3*.25
PWM 7,50,chB,5+servo4*.25
I try also DutyA
But it does not work.
Best regards,
Georges
Posted: 07:41pm 31 Oct 2024
What specific version of the firmware are you using? Let me know and I'll post a version with a specific SERVO command for you to play with/test.
georgestheking
Posted: 07:45pm 31 Oct 2024
I use version 5.08 on picomite RP2040.
Servo need a 1 ms to 2 ms pulse every 20 ms.
Thanks for your help,
Georges
Edited 2024-11-01 05:55 by georgestheking
Posted: 07:50pm 31 Oct 2024
Try this
PicoMite.zip
Set the pins you want as PWM outputs e.g.
SETPIN GPn,PWM
Then use the servo command
SERVO channel, posA [,posB]
posA and posB can be between -20.0 and 120.0%
Make sure you understand which pins are on which PWM channel (see manual) and note that you can omit posA or posB but not both and if you want just posB then include the extra comma
e.g.
SERVO channel,,posB
This functionality will be part of the 6.00.00 release when finalised
Edited 2024-11-01 05:53 by matherp
stanleyella
Posted: 08:48pm 31 Oct 2024
  matherp said  Try this
PicoMite.zip
SETPIN GPn,PWM
e.g.
SERVO channel,,posB
I always used pulse out gcb to control mini servo. not tried on mmbasic, never thought of pwm. 1.5ms is mid position 1ms left to 2 ms right every 20 ms
