Forum Index : Microcontroller and PC projects : GPRMC vs GNRMC
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052 |
Has the NMEA sentence changed from GPRMC to GNRMC. I have some V.KEL 2828U8 GPS modules that only work with GNRMC whereas the older U7 model worked ok with GPRMC. I recently fitted a NEO6M to one of Geoff's GPS trackers because the module has battery backup and it won't work whereas the V.Kel 2828U7 works ok. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6606 |
What device and firmware version? The later firmware should handle both CPRMC and GNRMC Jim VK7JH MMedit |
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
https://blog.bliley.com/the-differences-between-the-5-gnss-satellite-network-constellations The first two characters after the $ sign identify the origin of the signal. The main prefixes are: BD or GB = BEIDOU GA = GALILEO GP = GPS GL = GLONASS The GN prefix is used in the case of mixed signals, for example GPS + GLONASS. |
@ Jim, not on a MM or Pico it is Geoff's "GPS Tracker" from his web site. I had a look at the source file but would not know where to start. The code is probably 10 years old. However a few months back I found that the V.KEL2828 U8 version would only work with the Picomite and not the MM unless I used GNRMC and not GPRMC in my code. I don't think the MM has the GPS function like the Picomite does. I don't know how hard it would be for Geoff to update the tracker code, fairly easy I would think. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
@ goc30, see HERE . I think the newer V.KEL U8 version only outputs the GNRMC sentence not GPRMC> "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
This is a good time to put a picomite on a daughter-board and be future proofed. VK7JH MMedit |
I've already made a PicoMite Backpack PCB, but this is not a Picomite the tracker uses an MX250 chip. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
My suggestion is to remove the MX250 and fit a picomite. You obviously can't just plug it in so an adapter board is required. The pins on the pico are very configurable so you can use pins close to the MX250 ones to make the adapter board easier to do. Once the pico is fitted, you can program an equivalent program in MMBasic. Jim VK7JH MMedit |
Thats a lot of trouble to go to, I can just use a V.KEL2828 U7 version that works ok with the tracker, I was just trying the NEO6M because it has battery backup for a faster start, not that it is all that necessary. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Of course, it depends on the manufacturer of the GPS card, and even on the date of manufacture. Chinese suppliers, for the most part, have been integrating GLONASS for a few years, while US manufacturers ignore the russian network. One day you receive a card with an old circuit that sends GPRMC, and a few days later, the same supplier will send a card with a circuit recoding GNRMC. And if it's the opposite, it's because the supplier is selling off its old stock |
I finally got this working OK. Geoff was unable to make changes to the original Tracker software but suggested I change the parameters in the GPS module using U_BLOX U_Centre. It was a bit of a learning curve but I successfully changed the baud rate and the ability to receive GPRMC. Thanks Geoff. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
