Forum Index : Microcontroller and PC projects : Pico PUS 2W
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
https://shop.pimoroni.com/products/pimoroni-pico-plus-2-w?variant=42182811942995 Pico plus 2 w RP 2350 A top of the line Pirate-brand RP2350 microcontroller with all the goodies - 16MB of flash, 8MB of PSRAM, USB-C, Qw/ST and 2.4GHz wireless / Bluetooth. Maybe….Peter?…. ![]() Edited 2024-10-15 16:13 by atmega8 |
Seen it. You are advised not to bother unless you are going to sort out how it works. It's not supported in the Pico SDK and goodness knows what Pimorini have done. At least you'll stand a chance of getting a board that will work with HDMI if you wait for the official one. The Plus 2 doesn't and neither does the PGA2350. . Edited 2024-10-15 16:32 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
