Local Time 11:12 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : double quote in strings: question
Posted: 10:13am 04 Oct 2024
For most of you this will be simple, but I have not found a solution yet.
In a basic program you can
a$="hello"
But if you want to execute this from a script file you have to
EXECUTE " a$="hello" "
But how to get the double quotes around the "hello". I tried ""hello"" and \"hello\"
and chr$(34)hellochr$(34)...
Just have not found it yet...
anyone ?
Martin H.
Posted: 10:18am 04 Oct 2024
? CHR$(34);"HELLO";CHR$(34)
or
a$=CHR$(34)+"HELLO"+CHR$(34)
with EXECUTE I get an Error: Unknown command
Edited 2024-10-04 20:25 by Martin H.
'no comment
Posted: 10:23am 04 Oct 2024
a$=chr$(34)+hello+chr$(34)
or
PicoMite Manual page 27
OPTION ESCAPE
a$="\qhello\q"
a$="\031hello\031"
Posted: 10:44am 04 Oct 2024
  matherp said
OPTION ESCAPE
a$="\qhello\q"
a$="\031hello\031"
Presumably you mean:
a$="\034hello\034"
But IMO that's a snafu as (by C convention) that should be the syntax for an octal sequence, not a decimal sequence.
If you aren't on the PicoMite then these might be of use:
' Decodes a string containing "C" escape codes.
' Note: does not handle octal escape codes.
' state%:
'   0 = base state
'   1 = looking for escape code
'   2 = expecting 1st hex digit
'   3 = expecting 2nd hex digit
Function str.decode$(s$)
 Local ad%, ch%, prev%, state%, t$
 For ad% = Peek(VarAddr s$) + 1 TO Peek(VarAddr s$) + Len(s$)
   ch% = Peek(Byte ad%)
   Select Case ch%
     Case &h5C ' \
       state% = 1
     Case Else
       Select Case state%
         Case 0
           Cat t$, Chr$(ch%)
         Case 1
           Select Case ch%
             Case &h22 : ch% = &h22 ' \"
             Case &h27 : ch% = &h27 ' \'
             Case &h30 : ch% = &h00 ' \0
             Case &h3F : ch% = &h3F ' \?
             Case &h5C : ch% = &h5C ' \
             Case &h61 : ch% = &h07 ' \a
             Case &h62 : ch% = &h08 ' \b
             Case &h65 : ch% = &h1B ' \e
             Case &h66 : ch% = &h0C ' \f
             Case &h6E : ch% = &h0A ' \n
             Case &h71 : ch% = &h22 ' \q
             Case &h72 : ch% = &h0D ' \r
             Case &h74 : ch% = &h09 ' \t
             Case &h76 : ch% = &h0B ' \v
             Case &h78 : state% = 2 ' \x
             Case Else : Cat t$, "\"
           End Select
           If state% = 1 Then
             Cat t$, Chr$(ch%)
             state% = 0
           EndIf
         Case 2
           Select Case ch%
             Case &h30 To &h39, &h41 To &h46, &h61 To &h66 ' 0-9, A-F, a-f
               prev% = ch%
               state% = 3
             Case Else
               Cat t$, "\x" + Chr$(ch%)
               state% = 0
           End Select
         Case 3
           Select Case ch%
               Cat t$, Chr$(Val("&h" + Chr$(prev%) + Chr$(ch%)))
             Case Else
               Cat t$, "\x" + Chr$(prev%) + Chr$(ch%)
           End Select
           state% = 0
       End Select
   End Select
 Next
 Select Case state%
   Case 1 : Cat t$, "\"
   Case 2 : Cat t$, "\x"
   Case 3 : Cat t$, "\x" + Chr$(prev%)
 End Select
 str.decode$ = t$
End Function
' Encodes a string using "C" escape codes.
Function str.encode$(s$)
 Local ad%, ch%, t$
   Select Case ch%
     Case &h00 : Cat t$, "\0"
     Case &h07 : Cat t$, "\a"
     Case &h08 : Cat t$, "\b"
     Case &h09 : Cat t$, "\t"
     Case &h0A : Cat t$, "\n"
     Case &h0B : Cat t$, "\v"
     Case &h0C : Cat t$, "\f"
     Case &h0D : Cat t$, "\r"
     Case &h1B : Cat t$, "\e"
     Case &h22 : Cat t$, "\q"
     Case &h27 : Cat t$, "\'"
     Case &h3F : Cat t$, "\?"
     Case &h5C : Cat t$, "\\"
     Case < &h20, >= &h7F : Cat t$, "\x" + Hex$(ch%, 2)
     Case Else : Cat t$, Chr$(ch%)
   End Select
 Next
 str.encode$ = t$
End Function
allowing you to write either:
a$=str.decode$("\qhello\q")
or:
a$=str.decode$("\x22hello\x22")
Edited 2024-10-04 20:52 by thwill
Posted: 11:01am 04 Oct 2024
Nobody uses octal anymore so I re-purposed that syntax - yes it should be \034
From the manual
  Quote  \nnn any The byte whose value is given by nnn interpreted as a decimal number
\&hh any The byte whose value is given by hh… interpreted as a hexadecimal number
Posted: 11:07am 04 Oct 2024
  matherp said  Nobody uses octal anymore so I re-purposed that syntax - yes it should be \034
Whilst I personally stay clear of octal I still think it dangerous to subvert convention in an engineering context such as a programming language.
YMMV,
Posted: 11:11am 04 Oct 2024
Thank you for your help.
Posted: 11:25am 04 Oct 2024
  thwill said  ... I still think it dangerous to subvert convention in an engineering context such as a programming language.
... though I now observe you are not the only one to have done it : https://freebasic.net/wiki/TblEscapeSequences
I'll get back in my box,
disco4now
Posted: 11:29am 04 Oct 2024
The EXECUTE command expects a string.
Use chr$(34) to put the extra quotes.(or OPTION ESCAPE with \q )
pass to EXECUTE as below.
execute "a$="+chr$(34)+"hello world"+chr$(34)
> ? a$
hello world
F4 H7FotSF4xGT
Posted: 11:38am 04 Oct 2024
I looked at your proposals and I feel so stupid.
I wanto to add test to a log (in this case a text array called r$() and use pointer i. This routine will later change into writing to a file in the filesystem.
sub add_log(a$)
 r$(i)=a$
 inc i,1
end sub
I run a script file, and when it it should store text in the log file this is the current code (I want to execute txt$).
   read command$
   select case command$
     case "EXE"
       read p:read txt$
       execute txt$+chr$(13)
The txt$ is read from DATA statements
 data "EXE",0,"add_log(str$(a)+chr$(32)+chr$(109)+chr$(87))"
and above works. It adds the value of a (i.e. 100), and then the text " mW".
i.e. "100 mW" to r$(i)
I try to use the escape codes, so I won't have to translate every ASCII character manually. So I try...
 data "EXE",0,"add_log(str$(a)+\q mW\q)"
 data "EXE",0,"add_log(str$(a)+"\q mW\q")"
 data "EXE",0,"add_log(str$(a)\q mW\q)"
 data "EXE",0,"add_log(str$(a)"\q mW\q")"
O coarse I also tried \034.
B.T.W. MMB4L does error on OPTION ESCAPE
Edited 2024-10-04 21:40 by Volhout
Posted: 11:49am 04 Oct 2024
  Volhout said  B.T.W. MMB4L does error on OPTION ESCAPE
Yes, sorry @Volhout, I don't think I'll ever implement OPTION ESCAPE* in MMB4L, though I have been considering:
a$ = c"String using C escape sequences"
a$ = !"String using FreeBASIC escape sequences"
or something similar.
In the meantime str.encode$() and str.decode$() are your friend .
* At the risk of controversy I think it's a broken design. One issue (in addition to being different from C escapes) is that because it's not on a per-string basis Peter had to "hack" around any place where a string was being used as a file path (which frequently contain the \ character but don't mean it to introduce an escape).
YMMV,
Edited 2024-10-04 21:50 by thwill
Posted: 12:56pm 04 Oct 2024
I've seen BASIC implementations that allow both single and double quotes. You have to match the pairs though:
print "'this is a string'"
'this is a string'
print '"this is another"'
"this is another"
print "'a load of rubbish"'
'a load of rubbish
(and probably an error message)
Neat, but probably non-standard.
Posted: 01:53pm 04 Oct 2024
Mick,
... and then can't have comments starting with a single quote (I guess).
Posted: 01:55pm 04 Oct 2024
  Volhout said
   read command$
     case "EXE"
       read p:read txt$
I suspect the chr$(13) is not needed.
Posted: 03:41pm 04 Oct 2024
Good point, John. I can't honestly remember.
toml_12953
Posted: 07:47pm 04 Oct 2024
  disco4now said  The EXECUTE command expects a string.
> ? a$
hello world
In some BASICs (such as ANSI) you can do this:
a$="She said, ""I see the tower!"""
using two quotation marks to mean one.
In some you can use either the apostrophe or quotation mark like this:
a$='She said, "I can see the tower!"'
b$="This is Sam's coat"
whichever mark is needed inside, the opposite one is used to enclose the entire string.
