Local Time 11:12 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Programming PICMX250
palcal
Posted: 10:23pm 03 Oct 2024
I have always had trouble using my PicKit3 programmer getting it to connect. I bought aa MPLAB Snap but when I try to use that I get a message
"You have entered an invalid value (null) for the Voltage Level on the Snap Power property page."  wherever that is.
I don't think this would work but if I put the 250 chip on a 170 board would it program via the 1455 using the PicProg GUI.
Posted: 10:35pm 03 Oct 2024
They are in the same family so it should work.
I have successfully programmed a couple of MX270 chips (one for Geoff's ASCII terminal and the other for the USB console version of MMBasic) using pic32prog.exe via an MM2 as the programmer and TassyJim's MMflash windows front end.
It can also use a MicroBridge or Arduino Nano as the programmer. The MMflash.zip on his site has all the info.
For the Snap, I  have a vague memory that it doesn't supply power so you can't use that option. Instead run a wire from the Snap 3.3V line to the PIC chip.
Edited 2024-10-04 08:44 by phil99
palcal
Posted: 11:06pm 03 Oct 2024
Thanks Phil, it worked OK. Should have tried that first, Iv'e wasted hours.
palcal
Posted: 12:10am 04 Oct 2024
Well my board is up and running, I just saw the boot load button, maybe if I had have pressed that the PicKit3 woul have worked. So long since I have used the PicKit programmer I was a bit rusty.
Posted: 01:13am 04 Oct 2024
If it makes you feel any better, I've never had a stellar success with the PK3 and the Microchip IPE.
The 1455 MicroBridge thing ALWAYS works, or if it doesn't, it's something simple that I have done stopping it.  I basically don't bother with the PK3 anymore for ANY of the PIC32 chips used for the MM or MM+, I always use the 1455 MB method which "Just works".
The PK3 is very useful, setup as a stand-alone programmer, and I have a PK3 specially setup just for programming 1455 chips, but as for trying to use the PK3 via USB and the Microchip IDE/IPE, I have not used that setup for years now.
Posted: 06:29am 04 Oct 2024
IIRC the PK2 always worked better than the PK3 for me. It's ages since I used either though and, TBH, I don't even know where either of them are at the moment! The PK3 handles a wider range of chips but that seems to be its only advantage.
Posted: 07:12am 05 Oct 2024
Regarding the PICKit 2; I found that by using a program called PICkit2minus you can program many 8, 16 and 32-bit Microchip microcontrollers including the PIC32 with the PICKit 2.
PICkit2minus has a good graphical user interface and will also work with the PICkit 3 so it can also be used as your main programming software for both the PICkit 2 and 3.
I found PICkit2minus here: http://kair.us/projects/pickitminus/index.html
