Local Time 11:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Lightbulb / Duh Moment  with ON ERROR SKIP
Chopperp
Posted: 12:13am 20 Sep 2024
After many years of trying to understand the ON ERROR SKIP(nn) command, I finally worked it out. (I think)
I was doing some tests with this command & wasn't working as I thought it should.
I re-read the following for the umpteenth time & I finally saw what I was missing...
  Quote  ON ERROR SKIP will ignore an error in a number of commands (specified
by the number 'nn') executed following this command.
I missed out on seeing
  Quote  will ignore an error in
I was thinking that it missed the specified number of commands , not the error generated by them. The commands are still executed.
The example below now makes sense
  Quote  ON ERROR SKIP 3
WEB NTP -10
IF MM.ERRNO THEN WEB NTP -10
IF MM.ERRNO THEN PRINT "Failure to connect to the Internet" : CPU RESTART
All statements are executed but the errors on the first 3 are ignored.
Now, I have to go though a number of my programs to-re appraise my use of this command.
Brian
ChopperP
