Local Time 15:48 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : could mmb be compiled?
stanleyella
Posted: 08:13pm 19 Sep 2024
Posted: 08:14pm 19 Sep 2024
If you write a compiler for it
stanleyella
Posted: 08:27pm 19 Sep 2024
  matherp said  If you write a compiler for it
oops messed up. was going to say used great cow basic and it's got a compiler so produces fast code for 8 bit.
but would a mmbasic "compiler" make it faster?
PeteCotton
Posted: 09:02pm 19 Sep 2024
I'm of the mindset that it wouldn't make as much of an impact as you might think (but I could be wrong).
If you're talking about games, then sure it would speed up the loops and if statements, but the bulk of the time in a game loop is copying graphics between memory locations, rotating them etc. Those are already written in highly efficient compiled/machine code. Most other intensive tasks (enemy AI) can be split over multiple game loop iterations.
If it's for very fast I/O, then chances are that you will want more granular control over the timing than a compiler would allow for.
Posted: 09:22pm 19 Sep 2024
It could be compiled if you rewrote most of it from the bottom up, I suppose. I doubt if there's any other way as it was written purely as an interpreter.
If you absolutely *have* to have some lightning fast sections then you cam use (well commented) CSUBs. ;)
Remember that even compiled programs usually spend lots of time waiting for something to happen. They just do nothing faster. :)
PhenixRising
Posted: 09:55pm 19 Sep 2024
I think the nearest you can get is B4R, part of the B4X suite.
They're doing ESP and there has been a limited amount of Pico stuff. I haven't checked in a while.
Basic syntax but kinda event driven which I have never really taken to.
Posted: 10:11pm 19 Sep 2024
Some parts would be "awkward", such as EVAL & EXECUTE.
Others would stretch a lexer/parser.
And... why do it?
