Local Time 15:47 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Olimex Board
Plasmamac
Posted: 05:19pm 12 Sep 2024
I can’t get it to run 😵‍💫 what do I need todo?
Plasma
Justplayin
Posted: 05:38pm 12 Sep 2024
First silly thought... did you connect the USB cable to the connector on the Olimex board instead on the Pico?  The USB connector on the Olimex has no data lines and is for power only.
Second, you may need to connect SJ1 on the back of the board for HDMI to work for your monitor.
Edited 2024-09-13 03:41 by Justplayin
stanleyella
Posted: 06:01pm 12 Sep 2024
> option list
PicoMiteHDMI MMBasic Version 6.00.00b6
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION KEYBOARD UK
OPTION CPUSPEED (KHz) 315000
OPTION DISPLAY 24, 80
OPTION HDMI PINS  1, 3, 7, 5
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION MODBUFF ENABLE  192
OPTION PLATFORM OLIMEX
it's OPTION PLATFORM OLIMEX
> made it work 4 me
stanleyella
Posted: 07:05pm 12 Sep 2024
try in terminal OPTION PLATFORM OLIMEX
Posted: 07:08pm 12 Sep 2024
Think it may be the following you type (at least I did, and it worked for me):
OPTION RESET OLIMEX
Plasmamac
Posted: 07:12pm 12 Sep 2024
come not back
Plasma
Posted: 07:18pm 12 Sep 2024
Hi Plasma,
Re-install the software,
type "OPTION RESET OLIMEX"
OPTION RESET puts all the IO in order (HDMI)
OPTION PLATFORM only gives your Pico a name.
You can always type
OPTION RESET LIST
And then you see what hardware platforms are supported. OLIMEX should be among them.
Edited 2024-09-13 05:20 by Volhout
Plasmamac
Posted: 09:15pm 12 Sep 2024
ok , after a re install ive got hdmi
but the sd card isnt working .
> b:
> files
Error : There is no valid FAT volume
is 16 gb to big and not supported ? what format should i use?
every format i test isnt working.
thx
Plasma
stanleyella
Posted: 10:43pm 12 Sep 2024
  Plasmamac said  ok , after a re install ive got hdmi
> b:
> files
thx
dunno wots up. what;s option list say
stanleyella
Posted: 11:17pm 12 Sep 2024
16gb maybe too much
The firmware will work with cards up to 32GB formatted in FAT16 or FAT32 and the files created can also be
read/written on personal computers running Windows
Posted: 11:54pm 12 Sep 2024
16GB should work, but some cards appear to need a strong pullup on MISO (SD_SDO) at the moment they are inserted. If it isn't there they go to sleep.
Adding 4.7kΩ pullups (to 3.3V) to MISO and perhaps MOSI and CS is worth a try.
Edited 2024-09-13 09:55 by phil99
Plasmamac
Posted: 07:35am 13 Sep 2024
Hmm ok , the manual says up to 32 gb with fat32.
I will try a new card on other boards and also the pull up.
What brand are the other olimex board owner using?
Thx
Plasma
Posted: 08:05am 13 Sep 2024
I am successfully using a SanDisk Ultra, and a  ‘standard’ SanDisk  without any issues (both 16GB)
