Local Time 11:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2350 HDMI with 720P goodness
     Page 1 of 4
Posted: 02:42pm 06 Sep 2024
Download from here
Use
OPTION WIDESCREEN ON/OFF or ENABLE/DISABLE to switch to 1280x720 720P mode
MODE 1 ' 1280x720x2-colours with RGB332 tiles (use the TILE command as normal)
MODE 2 ' 320x180x16colours with optional layer (no memory usage) and colour mapping to RGB332 palette
MODE 3:' 640x360x16 colours with optional layer (significant memory usage) and colour mapping to RGB332 palette
Default font for mode 1 is 3 which is now 16x24
Default font for mode 2 is 7
Default font for 3 is 1
and if you want to edit in more detail
Edited 2024-09-07 00:47 by matherp
Plasmamac
Posted: 02:46pm 06 Sep 2024
its become better every day , thx peter
Plasma
Posted: 03:04pm 06 Sep 2024
brilliant achievement Peter!
rob   :-)
homa
Posted: 03:43pm 06 Sep 2024
Too bad, it doesn't work for me (720p, all modes), even though it's a full HD monitor (HP 2309m) with DVI input.
> option list
PicoMiteVGA MMBasic USB Edition  6.00.00b6
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 315000
OPTION SDCARD GP5, GP6, GP7, GP4
Do you still have any adjustment screws?
Edited 2024-09-07 01:48 by homa
Posted: 04:15pm 06 Sep 2024
I've checked it both normal and USB versions using a bog standard 1080p monitor. I've also checked the signals on the scope and the clock timing is pretty much perfect.
720P is a TV standard rather than a normal monitor standard but is the only widescreen mode that has a clock speed in range of the RP2350 - 371.25MHz (rounded to 372MHz - 0.2% error). My monitor is perfectly happy with a 375MHz clock speed so I don't think the trivial error is the issue - the advantage of a clocked system unlike VGA.
Are you using  270 ohm series resistors on all lines? My tests are using my little I/F board and the Olimex board. In both case the signal lines form the Pico2 to the HDMI socket are very short. At 372MHz signal integrity is likely to be an issue if breadboarded.
Even works on one of the little 800x480 displays with the multi-input adapter board
Edited 2024-09-07 02:23 by matherp
homa
Posted: 04:37pm 06 Sep 2024
it works on my tv :-) but that's not a permanent option.
I'm about to switch from the dvi input to the hdmi on the monitor ... but I'm afraid that won't work.
What I noticed: in mode 3 and then “files” changes the font?! that looks strange.
Otherwise good job!
Switching between widescreen on/off is only possible via OPTION? I tried it in a small test program. The first switch works, but then the program is closed, right?
homa
Posted: 05:00pm 06 Sep 2024
As feared, no improvement at the other entrance. This shows the OSD info normal 4:3 vs 720p:
Edited 2024-09-07 03:01 by homa
homa
Posted: 05:05pm 06 Sep 2024
No breadboard
I'm using that at the moment:
I took part in the Plasmamac collective order and an Olimex board has also been ordered.
homa
Posted: 05:13pm 06 Sep 2024
> option widescreen off
> option list
OPTION KEYBOARD GR
> option cpuspeed 372000
Error : CpuSpeed 126000, 252000, 378000, 157500 or 315000 only
> option widescreen on
> option list
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 372000
OPTION DISPLAY 45, 80
OPTION WIDESCREEN ENABLE
OPTION DEFAULT FONT 3, 1
> option cpuspeed 350000
> option cpuspeed 315000
> option list
OPTION KEYBOARD GR
OPTION DISPLAY 30, 40
okay, changing the cpu speed ends the widescreen mode
but it doesn't work the other way around
stanleyella
  homa said  No breadboard
how to get on the hdmi train? no idea where I get a ticket. will there be ae or ebay addon boards soon?
hdmi not for users but for teckno guys.
Posted: 05:21pm 06 Sep 2024
  Quote  This shows the OSD info normal 4:3 vs 720p:
The 720P timings are exactly correct see here
  Quote  Switching between widescreen on/off is only possible via OPTION?
Yes: Lots of things that can only be done on initialisation
Edited 2024-09-07 03:22 by matherp
homa
Posted: 05:22pm 06 Sep 2024
Buy your ticket here
https://learn.adafruit.com/adafruit-dvi-sock-for-pico/pinouts
homa
Posted: 05:25pm 06 Sep 2024
Peter,
I believe you, your work is usually almost perfect!
I'm annoyed about my monitor! I was hoping that there would have been a few more adjustment screws as an option.
But I will test other monitors ...
Unfortunately not until tomorrow.
Matthias
Edited 2024-09-07 03:26 by homa
  Quote  Buy your ticket here
or here
With this one use "OPTION RESET OLIMEX" to fully configure it
stanleyella
Posted: 05:38pm 06 Sep 2024
my point was vga on 2040 easy , the manual
ili9341 touch and sd card easy, the manual
hdmi or dvi rocket science that is too complicated for hobbyist, thick folk :(
Posted: 05:53pm 06 Sep 2024
HDMI on the RP2350 is equally easy
Wire pins GP12 to GP19 to an HDMI breakout or use one of the boards proposed. Then load the PicoMiteHDMI firmware - that's it. Simples.
To make it really easy use the Olimex board. Plug a Pico2 into it. Load the PicoMiteHDMI firmware and type "OPTION RESET OLIMEX" at the console
That will set up everything including the SDcard ready for use.
If you want to try the 720P mode
Type "OPTION WIDESCREEN ON"
stanleyella
Posted: 06:06pm 06 Sep 2024
  matherp said  HDMI on the RP2350 is equally easy
thankyou, dunno what olimex is though, my bad.
just remember logic green technology 328p being twice as fast as arduino 328p and thought that would be the same with pico2 over 2040 but it's gone totally graphics, which is fantastic but unexpected.
I guess vga is the same and 640x320 16 colour is hdmi only
Posted: 06:08pm 06 Sep 2024
  Quote  thankyou, dunno what olimex is though, my bad.
I posted the link 4 posts above
Posted: 06:16pm 06 Sep 2024
Send your money Here Stan. :)
JanVolk
Posted: 06:19pm 06 Sep 2024
homa,
The smd resistors on this board are 220 ohms what could make a difference?
https://learn.adafruit.com/adafruit-dvi-sock-for-pico/overview
Jan.
     Page 1 of 4
