Local Time 11:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: PCF8575 I2C I/O Expander
Posted: 05:17pm 05 Sep 2024
Hi folks,
Would one of these be as trivial as I suspect to drive from MMBasic on the PicoMite ?
Yes, I know I'm not supposed to be getting distracted .
Posted: 05:46pm 05 Sep 2024
The original PCF8574 is a 5V I2C device.
The PCF8575 looks like a dual 8574. But is works on 3.3v also.
I think this would work fine on a pico or cmm2.
16 extra digital IO’s
Software interface is simple, to send data out, you write chip address and the 16 bits(2 bytes).
To read inputs,you have to make sure you write the bits you use as input, with output value 1
Then you read 2 bytes.
No registers to worry about.
Hardware you needed know that the outputs are switching to ground. A LED must be connected between the output and 3v3
Edited 2024-09-06 03:58 by Volhout
stanleyella
Posted: 06:57pm 05 Sep 2024
I only tried https://www.microchip.com/en-us/product/mcp23017
but it's fine/// is it?
PhenixRising
Posted: 07:20pm 05 Sep 2024
Don't know if this is of any help
Posted: 07:35pm 05 Sep 2024
Actually I'm looking to read (a lot of) buttons rather than drive LEDs ... sometimes I think there are only two things in hobbyist electronics .
Perhaps the PCF8575 may not be the best thing, looks like I need a pull-up resistor on every input so that's going to be drawing x16 current with none of the buttons down ?
Edited 2024-09-06 05:35 by thwill
Posted: 08:10pm 05 Sep 2024
I've played with these or similar, but can't locate code.
scratch this ]Isn't the point of writing 1s to it (per Volhout), that if you read back a zero instead of a 1, it means your button connecting to 0V has been pressed?]
Isn't the point of writing 1s to it (per Volhout), which, because things are inverted, represents a 0, that if you read back a zero instead of a 1, it means your button connecting to 3V3 has been pressed?
Here's code to write to the similar PCF8574 (8-bit):
' i2c_pcf8574.bas
Dim integer k1=&b10101010,k2=&b01010101
SetPin 6,7,i2c
I2C open 100,100
 I2C write &h20,0,1,k1: I2C write &h12,0,1,k2: Pause 500
 I2C write &h20,0,1,k2: I2C write &h21,0,1,k1: Pause 500
 If Inkey$="x" Then Exit
Loop
I2C write &h20,0,1,255: I2C write &h21,0,1,255 ' turn off
(This inverted logic confuses me regularly.)
Edited 2024-09-06 06:19 by lizby
stanleyella
Posted: 08:16pm 05 Sep 2024
I only wanted buttons not high speed. I got code from a nice forum guy
mode 1
option autorun on
OPTION EXPLICIT
OPTION DEFAULT NONE
dim integer porta_bits,portb_bits
'SETPIN gp20, gp21, I2C
'I2C OPEN 100,100
const mcp23017 = &h20 ' A2, A1, A0, R/W all connected to 0V
Const i2caddr=mcp23017
const IODIRA = &h00 ' Port A IO Direction register DEFAULT = I/P
const IODIRB = &h01 ' Port B IO Direction register DEFAULT = I/P
const IOCON = &h0A ' IO Expander config register - address &h0B accesses  same register
const GPIOA = &h12 ' Port A General purpose register
const GPIOB = &h13 ' Port B General Purpose register
const OLATA = &h14 ' Port A latch register
const OLATB = &h15 ' Port B latch register
const GPUPA = &h0C ' Port C pull-up register
const GPUPB = &h0D ' Port B pull-up register
I2C WRITE MCP23017,0,2,IODIRA,255 ' set direction to input
I2C WRITE MCP23017,0,2,IODIRB,255 ' set direction to input
I2C WRITE MCP23017,0,2,GPUPB,&hff ' set weak pullups on all
Font 5
CLS
'then when you read:
'I2C WRITE MCP23017,0,1,GPIOB ' set the register to read
'I2C READ MCP23017,0,1,portb_bits ' read the B port
get_portb_bits
text 0,20,bin$(portb_bits,8)
text 0,60,str$(portb_bits)
Pause 100
Loop
sub get_portb_bits
end sub
Edited 2024-09-06 06:27 by stanleyella
Posted: 08:24pm 05 Sep 2024
Here is part of my earlier struggle, with Volhout's explanation below which made me (at the time) better understand how it worked. No resistors involved.
Posted: 08:27pm 05 Sep 2024
  lizby said  Isn't the point of writing 1s to it (per Volhout), which, because things are inverted, represents a 0, that if you read back a zero instead of a 1, it means your button connecting to 3V3 has been pressed?
I don't know ;-) it sometimes seems that a lot of what is written in hobbyist articles is by people as clueless as I, which is what makes TBS so helpful.
I think what you are suggesting is pin -> button -> 3v3 ... If you press the button the pin goes high, but in the absence of a resistor how much current is the pin now being asked to sink ? I suspect this is a teaching moment.
stanleyella
Posted: 08:54pm 05 Sep 2024
  lizby said  Here is part of my earlier struggle, with Volhout's explanation below which made me (at the time) better understand how it worked. No resistors involved.
I like lizbys preference. I used the weak pull ups and checked pins grounded
works great as stepper motor driver.. arduino https://www.youtube.com/watch?v=s5-5DNa36jk
Edited 2024-09-06 07:00 by stanleyella
barewires
Posted: 08:58pm 05 Sep 2024
Today I received a Bus Pirate 5. I have used the V3 in the past and mostly for I2C monitoring and probing.
https://buspirate.com/bus-pirate-5-rev-10-now-available/
Posted: 09:22pm 05 Sep 2024
I always prefer input low to activate. It's almost an industry standard and goes along with things like active low chip select lines.
Inputs do draw some current when not operated though. However, inputs also source some current into the pull-down resistor on active high inputs. You need to look at the spec of the input to see which is the better case if you are working with a lot of inputs on a battery supply.
If you have a serious amount of buttons to read then a matrix is the way to go - like they use for keyboards. :)  MMBasic can read 16 buttons with 8 bits.
stanleyella
Posted: 09:28pm 05 Sep 2024
  Mixtel90 said  I always prefer input low to activate. It's almost an industry standard and goes along with things like active low chip select lines.
or just use a keyboard.
Posted: 09:36pm 05 Sep 2024
  thwill said  I think what you are suggesting is pin -> button -> 3v3
I now think I got that right the first time but wrong the second.
You write 1s; if you read back with no button pressed, you get 1s; if you press the button connected to 0V, you get 0, which means the button is pressed.
Posted: 09:52pm 05 Sep 2024
Active low inputs have the advantage now that they are compatible with the RP2350. :)
Posted: 10:16pm 05 Sep 2024
  Mixtel90 said  If you have a serious amount of buttons to read then a matrix is the way to go - like they use for keyboards. :)  MMBasic can read 16 buttons with 8 bits.
I want to read 13 buttons using 2-3 pins ...
... I could of course do this by connecting 2 x 8-bit PISO shift-registers (CD4021) and a couple of resistor arrays (pull-up) but I thought that (a) I should try and learn some new tricks, and (b) I2C might be faster than clocking the data out of the shift-registers.
EDIT: I'd also like to do it "cheaply" which is why I wasn't looking at the Microchip devices.
Edited 2024-09-06 08:18 by thwill
Posted: 01:25am 06 Sep 2024
Well, I had a PCF8575, so I wired it up. It did not work as I expected. For me it worked without writing any output, with switching to high.
Here's the program (it was convenient for me to power it from pin 34, so the program sets that high).
Dim integer inp(2)
SetPin 6,7,i2c
SetPin 34,dout: Pin(34)=1 ' power the PCF8575
I2C open 100, 1000
  I2C read &h20,0,2,inp()
  Print Hex$(inp(0));"/"Hex$(inp(1));" ";
  Pause 3000
Loop
I connected a wire to 3V3 and moved it variously to different pins on the two ports. Every 3 seconds the program prints the hex value of the 16 PCF8575 pins. Here is sample output:
0/0 0/0 0/0 0/40 0/20 0/20 0/0 0/80 0/1 0/2 0/4 0/4 0/8 0/8 0/10 0/10 0/20 10/0 2/0 1/0 80/0 80/0 80/0
So for this simple test, the default pin value is low, and connecting it to VDD (as with a button) brings it high. Not the same as the PCF8574.
The module I have looks like the one you pictured, including the oddly labelled pins of the upper port, shown as p10 through p17.
Edited 2024-09-06 11:27 by lizby
Turbo46
Posted: 06:08am 06 Sep 2024
  Tom said  I could of course do this by connecting 2 x 8-bit PISO shift-registers (CD4021) and a couple of resistor arrays (pull-up)
KISS, If you don't want outputs or interrupts why make it more complicated than necessary?
Posted: 06:45am 06 Sep 2024
RP2040-Zero over I2C?
Program it to do what you like - it could even trigger an interrupt on pin change.
Posted: 06:57am 06 Sep 2024
  Mixtel90 said  RP2040-Zero over I2C?
That sounds like overkill, likewise using an 80-pin 2350 so there is more GPIO.
