Local Time 11:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hardware bug in RP2350
     Page 1 of 3
cosmic frog
Posted: 07:36pm 27 Aug 2024
"A Surprise Hardware Bug in Raspberry Pi's RP2350 Leads to Unexpected Pull-Down Behavior"
Link
Dave.
Posted: 07:45pm 27 Aug 2024
That is a more serious bug than the RP2040's ADC accuracy. And why only on bank 0.
Vohout
Edited 2024-08-28 05:46 by Volhout
EDNEDN
Posted: 08:14pm 27 Aug 2024
I hope they rev the chip quickly to get rid of this.   If they do, there won't be that many bad chips out in the wild.    I think I'll wait 6 months to get anything with a RP2350 in it.
Posted: 08:55pm 27 Aug 2024
Actually, this bug will most likely not be solved ever.
Applying an external pull-down resistor, and never using the internal pull-down, is a good solution. If you know what new maskings of a chip costs, you would not expect a change.
The ADC bug in the RP2040 is also never solved (after 3 years in the field).
I suggest Peter will remove the "pull_down" option on the SETPIN command to avoid problems.
Edited 2024-08-28 06:57 by Volhout
Posted: 09:12pm 27 Aug 2024
It could even be twiddled so that it appears to be right in MMBasic by adding extra commands when an instruction is given to control a pin while pull downs are active. It's almost certainly possible but probably not really worth the effort once you know about the bug.
EDNEDN
Posted: 09:19pm 27 Aug 2024
It just seems very sloppy to ask a vendor or partner to make a minor tweak to the output cell and then not even review the change.   Especially when the change is a totally different circuit and doesn't even resemble the original GPIO cell.
"I suggest Peter will remove the "pull_down" option on the SETPIN command to avoid problems."
Yup...   Fix it in the software...
Edited 2024-08-28 07:50 by EDNEDN
Posted: 09:50pm 27 Aug 2024
Using external pull-downs is an easy solution for standard inputs but how many devices with special comms protocols use pulldowns in the firmware? That can make life interesting.
My modules are waiting at the post office so I can see a lot of testing coming up.
I hope most use pull-ups, not pull-downs.
Posted: 12:10pm 28 Aug 2024
All,
In my testing today I have seen a Pico2 GPIO pin stuck at 2V (with a scope with 10meg probe impedance). This is on a Pico2. The pin was set to input (no pull-down enabled).
The pin returned to low or high state when actively driven, But in normal INPUT state it stayed at 1.95V before driven hard.
I have checked on the internet, and there is 1 other guy making the same observation.
without pull-down
This means that if you have a GPIO pin on a 2350 that is not driven with a low impedance, it potentially changes level. I have not yet seen it on a ADC enabled pin. That would be a real drama, since ADC's are typically not hard driven.
EDIT: looking at the noise in the forums on this bug, RP might be forced to do new mask for the chip, or accept it will not be the success the 2040 was.
Edited 2024-08-28 22:28 by Volhout
Posted: 12:47pm 28 Aug 2024
About the bug:
It is even more serous than I thought. Look at below pictures.
I have a 1kHz signal from a generator (3.3V), looking like this:
With a series resistor of 100k (yes, that is high impedance, but not terribly high) I apply this signal to a Pico2 GPIO pin (in this case GP0). This Pico2 is flashed with MMBasic, but NO PROGRAM IS RUNNING. This is just the default GPIO pin configuration after power up.
This is what the signal looks like:
You really need to drive the pin low impedance. High impedance will not work. Forums say that 9k ohm is maximum.
Posted: 12:57pm 28 Aug 2024
Oh dear, that's very poor performance. IIRC the ADC inputs on some PIC ICs had to be driven from 19K or less impedance but that's the lowest I've ever seen - and it didn't apply to digital inputs.
This could be a serious problem if it's not restricted to just pull down resistors.
PhenixRising
Posted: 12:58pm 28 Aug 2024
Hey Harm,
So I took your advice re: voltage divider for 5v input. Effectively, this is a 10K pull-down and a 4K7 from the 5V signal. Bit concerned about this because this is the encoder signals. Am I in good shape, do you think?
This is only on proto-board so I can re-assign to other pins. Do I understand correctly that this issue only relates to pins 0-7?
Or should I switch back to the RP2040?
Posted: 01:08pm 28 Aug 2024
Hi Phenix,
Effectively your impedance is 10k parallel to 4.7k, something like 3.3k.
That should be fine.
But this is all relatively new information. I personally fear we did not arrive at the bottom of this pit yet (we have not seen the worst).
If you are able to work with the RP2040, I would continue to do that.
Comming weeks may reveal more information, and there may be an official press release from RP about what is a safe value to use, and what is not. They may have a better overall view of tolerances, and what we can expect. The 9k ohm is comming from a forum member, in analyzing his particular RP2350.
I personally will not design anything right now around the RP2350. Appart from HDMI, it does not bring revolutionary new features (I did not need a 3'rd PIO yet). Maybe ony RAM. But I am not writing any huge programs (like PETSCII) at the moment. I can wait until the dust settles.
Edited 2024-08-28 23:09 by Volhout
Posted: 01:11pm 28 Aug 2024
I'd reduce the 10K to 6K8 and reduce the 4k7 to 3k9. It depends on what's driving it though.
Edited 2024-08-28 23:12 by Mixtel90
Posted: 01:21pm 28 Aug 2024
Phenix,
If you look at the datasheet, virtually ALL GPIO pins are in bank 0. Not just GP0...GP7.
EDIT: on my RP2350 Pico2, 10k ohm series impedance works when the signal is perfect (0V/3.3V), 20k ohm definitely not. So on my Pico2, I need 10k or lower as pulldowns.
Edited 2024-08-28 23:38 by Volhout
EDNEDN
Posted: 02:08pm 28 Aug 2024
  Volhout said
I personally will not design anything right now around the RP2350. Appart from HDMI, it does not bring revolutionary new features (I did not need a 3'rd PIO yet). Maybe only RAM. But I am not writing any huge programs (like PETSCII) at the moment. I can wait until the dust settles.
I'm not doing any boards.   But I'm in the same camp.  I don't want to get a bunch of RP2350's that don't have the proper circuitry to use the GPIO pins however I need.  I do like the support for the PSRAM but I have no immediate use for that right now.
I can wait.    And the more people that feel that way the more likely this gets fixed quickly.
Sasquatch
Posted: 02:22pm 28 Aug 2024
Yes, I can see your point!  However, somebody needs to do the testing to find the errors and limitations of the new device.  If they do a second revision, we want ALL the known problems fixed.
-Carl
Posted: 02:25pm 28 Aug 2024
Carl,
The doomsday scenario is that RP spin the chip to fix this, and that the surplus of faulty chips end up on cheap chineese clones.
So in the years ot come, you will find the faulty chips... not from RP, but potentially on every cheap clone.
The faulty chips already exist, potentially millions of them. So what now..?
I honestly think that the chip (under this RP2350 name) is already doomed.
Edited 2024-08-29 00:29 by Volhout
Posted: 02:48pm 28 Aug 2024
I predict excellent future sales in 10K pull up resistor packages and a loss of pull down input circuits. :)
I doubt if RP will fix this. They are more likely to bring forward the next new device (if at all possible) and let this slide quietly into obscurity as it gets overshadowed. There will probably also be a huge claim for damages against that outside supplier.
EDNEDN
Posted: 02:58pm 28 Aug 2024
  Volhout said  The doomsday scenario is that RP spin the chip to fix this, and that the surplus of faulty chips end up on cheap Chinese clones.
So in the years to come, you will find the faulty chips... not from RP, but potentially on every cheap clone.
Yikes!!!   That would be horrible.    Hopefully if they spin the chip they add an '-A' suffix so this doesn't happen.   If the chip becomes something like RP2350-A the end users can do a first level check they have a fixed chip.
Of course, with cheap labor the cheap clones will start stenciling a '-A' onto the bad chips and run the plant at full speed.
Edited 2024-08-29 00:59 by EDNEDN
stanleyella
Posted: 03:05pm 28 Aug 2024
2 pico2 just arrived from pimoroni, was about to solder header pins but just read this thread, downer.. but I only used inbuilt pullups for switching gpio to ground so maybe it won't be a problem , dunno though. sigh
     Page 1 of 3
