Local Time 12:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : last WebMite RC where?, idea and my problem
homa
Posted: 08:16am 18 Aug 2024
Hi Peter,
1) Where can I find the latest "official" RC for WebMite V5.09.00?
On https://geoffg.net/webmite.html  it is the RC5 from the date 26.06.2024.
In your screenshot I already saw RC7.
2) The command PIO assemble 1,".end program list" shows the HEX values. Could you also show the values in binary behind it? Then it would be easier to compare with the information in the raspberrypi manual. Thanks in advance.
3) I am currently having problems with the "PIO WRITE" and understanding the data flow: MMBasic -> FIFO -> OSR -> PIO (or pins)
in the current version "WebMite MMBasic Version 5.08.00".
OUT does not do what it is supposed to do in my opinion and therefore I would like to test the current beta and the additional output in binary would be the dream.
See also my question here: https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17155#225008
Matthias
Plasmamac
Posted: 08:19am 18 Aug 2024
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16834
Plasma
homa
Posted: 01:20pm 18 Aug 2024
Thanks, I know the thread. However, this is Peter's last entry on page 12. And it is only for the PicoMIte, not the WebMite. Hence my question about an exact link.
https://www.thebackshed.com/forum/ViewTopic.php?TID=16834&P=12#224292
  matherp said  Try this
PicoMite.zip
