Local Time 17:29 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VERY customizable W11 auto-installer!!!
Posted: 01:54am 24 Jul 2024
This is very interesting!
LINK...
I plan to try this out on a test machine.
EDNEDN
Posted: 03:13am 24 Jul 2024
Yes!   That is super helpful!   I'm going to use that to move a bunch of machines to Windows 11!
Thank You!
OA47
Posted: 03:46am 24 Jul 2024
I watched this episode a couple of days ago and thought that this will be the answer for my aging w10 machines but then I had a little bit of a reminder of years ago a similar scenario was at hand and it only lasted a couple of months before a Microsoft update closed the door and made the hardware incompatible again.
I am not sure that I would fully commit until the dust settles.
0A47
Posted: 05:36am 24 Jul 2024
I hear that, OA47, but could you not disable the W11 auto update...."Feature"?
It is certainly true that ANY of these cut-down version of Windoze, are really only for people who are prepared to be their own I.T. department when something goes wrong!
OA47
Posted: 05:53am 24 Jul 2024
  Quote  but could you not disable the W11 auto update
That would be OK if the OS was kept away from the internet but MS always describes these things as critical updates that you have to have or the world will stop turning.
0A47
Posted: 06:10am 24 Jul 2024
Hmmmmmmmmmm.......
Posted: 06:25am 24 Jul 2024
Personally I won't take risks with an OS. I'd like my system(s) so keep running, thanks. :)
I have used stuff like tiny versions of Windows in the past without problems, but times move on and every bit of protection you can get from nasties on the internet is needed. That means all security updates. Unfortunately we don't just have simple viruses to contend with now. Even day one types are vastly cleverer than we used to get.
You pays your money and you takes your choice. I'd even rate a tiny Linux distro like Puppy as being far more secure than a tiny Windows one. I have more trust in its developers - it isn't bait to get something nasty onto your home network.
Posted: 06:30am 24 Jul 2024
Interesting point.
I run Puppy on a couple of my NAS boxes.
PhenixRising
Posted: 08:14am 24 Jul 2024
Might not be for everyone but I use this
electricat
Posted: 10:28am 25 Jul 2024
Installed win11 on aged lenovo z710 :)
Downloaded WIN11 ISO from micro$oft
Generated and added autounattend.xml to original installation iso using UltraIso
Modified WIN10 registry as
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\Setup\LabConfig]
"BypassTPMCheck"=dword:00000001
"BypassSecureBootCheck"=dword:00000001
"BypassRAMCheck"=dword:00000001
"BypassStorageCheck"=dword:00000001
"BypassCPUCheck"=dword:00000001
Maunted  installation ISO from win10
Installed ... at least it boots up, updates etc.
Intalled without copilot, cortana etc.
Looks like win11 :)
My MMBasic 'sand box'
EDNEDN
Posted: 09:43pm 26 Jul 2024
Maybe I'm not understanding things.   But is this only for fresh installs?   Or can it be used to upgrade from Windows-10 to Windows-11 leaving all the applications and data ready to use?
Posted: 12:09am 27 Jul 2024
I believe it is for fresh/new installs only.
Most of the tiny Windoze versions are built like that, IE: not as an upgrade path, but as a completely new install.
hitsware2
Posted: 01:01am 27 Jul 2024
  electricat said
updates etc.
Oh Joy
my site
Posted: 06:37am 27 Jul 2024
So it comes with free CrowdStrike updates too?  ;)
electricat
Posted: 08:34am 27 Jul 2024
  Mixtel90 said  So it comes with free CrowdStrike updates too?  ;)
With all kind of "security" and "improvement" updates, Sir :)
  Quote  Or can it be used to upgrade from Windows-10 to Windows-11 leaving all the applications and data ready to use?
Even if that is possible, I wouldn`t try that. WIN11 would mess with activation, I think,  and you would be in trouble.
What I wanted to tray was - could I have installed WIN11 on old machine and would it be usable at all.
Even if it seems to work freshly installed, it would keep it offline ;)
Posted: 06:16am 28 Jul 2024
I just tonight, installed the W11 on a spare mini-PC, a BMAX B1-Pro(2-core 1.1GHz, 6GB RAM, 512GB SATA)
It all went painlessly, and W11 runs fine on this mini-PC, albeit a LITTLE slow, as the hardware spec is really a bit low for W11.
Improvements I made were to "Adjust for best performance" in the visuals, and to disable the automatic reboot on BSOD.  That makes this W11 a bit more responsive, as you would expect.  Surprised that these were not options in the auto-install script generator thing.  Perhaps they simply forgot - there are A-LOT of settings you can change.
The auto-installer correctly created a local account for me, along with my specified password - no need to sign in with a bloody MS account, something that I absouletly HATE about W11 by default.
I guess that with any PC or laptop, you COULD go into the BIOS and temporarily disable the WiFi adaptor, to FORCE W11 to create a local account, but if you DON'T do that, and W11 is able to find either an ethernet or WiFi connection, it will FORCE you to sign-in with a MS account, and I hate that so much, I can't tell you....
I can see this cut-down W11 concept, working very well for a system that you NEVER connect to the internet.  Thus, you never have to worry about some nastie getting into the cut-down system.  I build low-power FM radio stations for people now, and this version of W11 would seem to suit that kind of application well.
Just disable WiFi or unplug the ethernet, so there is pretty much zero risk of any nastie getting in there, but it allows you to run the latest radio-station automation software etc.
That is but ONE use case I can think of, but there probably are others.
