Forum Index : Microcontroller and PC projects : Framing Error
| LouisG Senior Member Joined: 19/03/2016 Location: AustraliaPosts: 130 |
Hi Guys, I got an error message at this line of code in a short program for Picomite. RUN [18] Device SerialRx 34, 4800, Msg$, 200, status% Error : Framing error > This is the command from the handbook: DEVICE SERIALRX pinno, baudrate, istring$, timeout_in_ms, status% [,nbr] [,terminators$] The above line is inside a Do Loop. Am using Version 5.08.00. I had it working OK with a previous version (called BITBANG SerialRx back then.) What is a Framing Error? How can I track it down? Not mentioned in the manual. Regards, Louis - |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
Just a guess. Perhaps it is to do with starting Rx in the middle of a Tx byte. Maybe you need to start Rx just before Tx begins, and ensure they stay synchronised. > do:Device SerialRx gp1, 9600, Msg$, 1000, status% : ? Msg$ :? :? status%, len(Msg$) :pause 990 :? :loop $GPRMC,230344.00,A,3730.57126,S,14521.66403,E,0.062,,150724,,,A*6A $GPVTG,,T,,M,0.062,N,0.115,K,A*22 $GPGGA,230344.00,3730.57126,S,14521.66403,E,1,08,1.00,584.2,M,-0.3,M,,*5B $GPGSA,A,3,04,09,07,27,16,30,03,08,,,,,1.78,1.00,1.47*0F $GPGSV,4,1,14,03,17 2 255 ºbÂb²b¢bªb?bÊb²b¢b²b bºbª²bªÂbªRº AMYbb ¢bÂb ²bªÂb bÊbº²b ?b¢²b bªb¢Âbb ¢b bb ºRºAMYbb ¢b ²b¢b b²bb bbºb²bb ¢bbºb ºb?b²Rº²AMYb¢b ¢bb²bºÂbbªb¢b bRººA11ºrªº b¢ª r²²Ê b¢ªrbþ$GPRMC, 2 255 Error : Framing error > option list PicoMiteVGA MMBasic Version 5.09.00RC5 |
Thanks Phil. Lucky you! At least you are seeing data of some kind. I'm not. Forgot to mention: Am getting the framing error without having any data stream coming in. The error appears immediately on encountering the above line of code in the first round of the DO loop. Doesn't even get a chance to print anything. Do Bitbang SerialRx 34, 4800, Msg$, 1500, status% Print Msg$ Print status% Might try going back to a previous firmware version. - |
I get that if Tx has started before starting Rx. Perhaps there is noise on your Rx pin? It should be idle high, any lows will look like the start of a byte. To test disconnect Tx and tie Rx pin to 3.3V. Then increase the time-out to 1000 and put Msg$ = "Looping" before the Device command and see if you still get the Framing Error. If that works try a pullup on the Rx pin - 1.8 to 3.3kΩ perhaps. In the case of the GPS receiver keeping it synchronised by setting a terminating character allows it to run, provided I start Rx between transmissions. do Device SerialRx gp1,9600, Msg$,500,status%,127,Chr$(13) ? Msg$:? ? status%,len(Msg$) pause 900 ? loop $GPRMC,014620.00,A,3730.56888,S,14521.66039,E,0.064,,160724,,,A*6D 3 67 $GPRMC,014621.00,A,3730.56894,S,14521.66039,E,0.056,,160724,,,A*60 3 67 $GPRMC,014622.00,A,3730.56898,S,14521.66044,E,0.030,,160724,,,A*65 3 67 $GPRMC,014623.00,A,3730.56906,S,14521.66043,E,0.081,,160724,,,A*6F 3 67 'etc, ad infinitum Edited 2024-07-16 14:53 by phil99 |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6118 |
Hi, Assuming 3.3V logic levels on the UART pins of your PicoMite. Please check if there is a pullup on the RX line. The RX line is connected to the UART, and the UART checks for a high-to-low transition on the RX line, to check for a start bit. But when the RX line is constantly low, this is treated as a "BREAK". This results in an error, since it violates the RS232 "frame" time (start bit/x bits/y stop bits). A constant high level on the RX line keeps the UART waiting for new data, which is normal operation. But constant low causes a framing error. Regards, Volhout PicomiteVGA PETSCII ROBOTS |
Thanks Volhout! IT NOW WORKS and receives data correctly. Your pullup resistor suggestion for the Rx line did the trick. I used 8.1k. However, I now see my next challenge. Will post tomorrow if still unresolved. - |
