Local Time 17:02 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Expansion Ports
Rickard5
Posted: 07:59pm 10 Jul 2024
I was Reading another CMM2 post and there were Port Maps (I don't know the proper name) for CMM2s that look nothing like the 2 I have, I love my CMMs so much I'm scared to fiddle with GPIO Port. That's why I love the Picomites worst thing I can do is blow up $2  that I have 150 of them. My CMMs have the PIN numbers labeled but not defined, how can I find the right pin definition for each one?
Posted: 09:07pm 10 Jul 2024
It's very much like the PicoMite but the pin numbers are different - you use SETPIN to configure what you want a pin to do. The various options are shown in the manual.
The layout of the GPIO port is also shown in the manual (get the right one for your CMM2 version). AFAIK the RetroMax will follow the same layout, but you will need the manual for that to be sure. The diagram shows what you can configure pins for, but they can be standard digital IO pins.
For example, you could make pin 33 an input with a pullup to 3V3:
SETPIN 33, DIN, PULLUP
You can read it with
PRINT PIN(33)
so, you could set up a loop:
'this will print the value of pin 33 every 10th of a second
'use Ctrl C to stop it.
DO
 PRINT PIN(33)
 PAUSE 100
LOOP
It will keep printing "1"
If you now put a wire between pin 33 and GND it will print "0" while the wire is there and go back to "1" when you remove it.
Rickard5
Posted: 09:50pm 10 Jul 2024
WOW
Thanks Mick
so you're saying all pins are Programable, can all Pins be 5volts ?
Posted: 10:37pm 10 Jul 2024
  Rickard5 said   can all Pins be 5volts ?
NO!
RTFM
Rickard5
Posted: 11:48pm 10 Jul 2024
@ TassyJim
I can't find the Manual otherwise I would read it, I get ton's of errors on Gizmo's website
Rick
Posted: 01:40am 11 Jul 2024
Try https://geoffg.net/maximite.html , the downloads are at the bottom of the page.
PS, If you are having trouble accessing Geoff's site perhaps the browser or OS security settings are the the problem. See if you can create an exception for that site in the settings. Or try another browser.
Edited 2024-07-11 15:23 by phil99
Posted: 06:26am 11 Jul 2024
Try the Brave browser. It's pretty nippy and I've had no problems with it on any web sites. I did have problems with Firefox on some sites.
The 5V pins are the ones marked 5V in the manual.
Quazee137
Posted: 09:46am 11 Jul 2024
Rickard5
A while back I made this for a school TBS
I have more if you want one. I think I may have the full kits.
Quazee137
Posted: 10:44am 11 Jul 2024
Hi Quazee137,
For what version of the CMM2 are these. I seem to remeber that the original connector (on the CMM2G1) was upside down. And that was changed at the CMM2G2. And if recall right, the latest incarnation CMM2G2V2 is back to G1 pinout.
I guess this is made in the high days of the CMM2, so for the G1..??
Edited 2024-07-11 20:45 by Volhout
Quazee137
Posted: 12:30pm 12 Jul 2024
Volhout Yes it is for CMM2G1. I also used it on a RPi Zero
Quazee137
Oh also a few of these 170Hatstand
Posted: 01:55pm 12 Jul 2024
I bought one of Quazee's cmm2 breadboards 4 years ago. Worked perfectly. Very Useful.
Also useful have been bigmik's CMM2 header breakout boards: (Big) Mick's CMM2 Breakout PCBs
Edited 2024-07-13 00:08 by lizby
Quazee137
Posted: 11:47pm 14 Jul 2024
Sadly its going away. It works great for many projects that use the
 RPi 40 pin buss.
 last chance :(
 I have used around 25 of these for my MM170 Hatstand based controllers making
  use of a few RPi hats and my own pcbs.
 Quazee137
