Local Time 12:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : my very simple PWM problem
DaveJacko
Posted: 09:20pm 01 Jul 2024
I can't get this 2-line program to work,
it must be me, it usually is...
setpin gp4,pwm2A
PWM 2,1000,50,0
'reports error pin not set for PWM
Try swapping 2 and 3 over
Posted: 09:44pm 01 Jul 2024
You have one pin set but the second line is trying to set the duty for two pins.
Try with
PWM 2,1000,50
You are setting a valid duty cycle (0) for a pin you haven't set as a PWM output
Try
PWM 2,1000,50
Posted: 09:51pm 01 Jul 2024
As channel 2B has no "Setpin gp5,pwm2B" try omitting it from the PWM command.
setpin gp4,pwm2A
PWM 2,1000,50
Edit. Too slow.
Edited 2024-07-02 07:51 by phil99
DaveJacko
Posted: 10:21pm 01 Jul 2024
thanks, guys! .. solved problem !
Jim, Peter, Phil
I'm just playing with a 1930's Bakelite micro-Ammeter
I collect these old things,
I like how a milliAmp from a pico can move a needle from the 1930's
Rickard5
Posted: 03:40am 04 Jul 2024
Dave I'm watching a Western Electric Black Rotary Dialer I Want Badly to acquire, and build a very Steam Punk Calculator with MMBasic on the Pico Use th dial as a number psd and a Button  matrix for operator buttons:) the hard part is how to use 8 segment LEDs for Displays. and I'd love to have a pull arm or a carriage line feed that ratchets on top as the enter Key as it would be a Reverse Polish Calculator! Something Very Brazil!
Posted: 07:52am 04 Jul 2024
7 (8 if you count the decimal point) segment displays are pretty easy to do. I wrote some GCBASIC routines ages ago to use a PIC chip as a driver for a 4-digit display.
You put the number to be displayed into a buffer. Then it's a lookup table to see which segments to light for the digit being handled at the time. You just keep stepping round the digits doing that. If you make each digit step on a SETTICK interrupt then all you need to do is write to the buffer, the interrupt will do everything else automatically.
Posted: 08:29am 04 Jul 2024
Rickard,
TM1637(4 digit) and TM1638(8 digit) LED display modules are cheap, and people have connected them to PicoMite before.
DaveJacko
Posted: 08:39pm 04 Jul 2024
Superb project, Rickard !
I have used the TM1637 etc with the uMite, easy and nicely retro.
However, I cannot get them to work with Pico.. very frustrated.
Same program, same timings, but the wrong segments light up.
I'll have a look around the backshed for a solution.
(and I'll also google the Brazil reference !)
Would like to use Nixies but expensive.
palcal
Posted: 09:09pm 04 Jul 2024
@ DaveJacko,  Did you get a clock to work with the MM and TM1637. I tried using Matherp's code HERE
I had no luck same with PicoMite.
DaveJacko
Posted: 09:30pm 04 Jul 2024
yes Palcal,
TM1637 works with MM,
don't with Picomite,
spent hours on it.
now gone off to play with HC-12/Pico zero/multicolor led  for a while
regs Dave
palcal
Posted: 10:43pm 04 Jul 2024
Did you use Peter'e code or your own. If your own can you post it here.
Mine works with Peter's code for about a minute and then just flicks random numbers all over the screen.
I'm using 28 pin with appropriate changes to pin nos. Peter used a 44 Pin don't know if that makes a difference.
Now it has stopped altogether, screen blank. Maybe faulty screen
Edited 2024-07-05 14:16 by palcal
Posted: 07:55am 05 Jul 2024
I don't know this chip at all, but if it's a timing issue how are you driving it?
I've just looked it up. It could be that it needs accurate timing, in which case you may need to use BITBANG BITSTREAM on the Pico. It's a pity it isn't standard I2C.
palcal
Posted: 09:01pm 05 Jul 2024
Peter published the original code back in 2016 Here
I'm wanting to make a small clock I can run from a battery.
DaveJacko
Posted: 09:06pm 05 Jul 2024
I don't believe it needs accurate timing,
I've tried with a pause 0.1 after every every level change,
( clk and dat, up  or down ), pico versions just light the wrong segments,
same wrong segments every time.
Palcal..
I've attached my code (inspired by Peter) for the Micromite,
works fine, no delays per se so probs way too fast..
' Clock demo 7 seg driver
' ok with pic pullup
' Dave J 2020
Option autorun on
dat=18 'pinout
clk=17
init
mnlp:
Pause 500
colon=colon Xor &H80
start
wrtb(&H40) 'comm1
stop
start
wrtb(&HC0) 'comm2
wrtb(dgt%(Asc(Mid$(Time$,4,1))-48))
wrtb(dgt%(Asc(Mid$(Time$,5,1))-48)Or colon)
wrtb(dgt%(Asc(Mid$(Time$,7,1))-48))
wrtb(dgt%(Asc(Mid$(Time$,8,1))-48))
stop
GoTo mnlp
'------------------- subs
Sub wrtb(b As integer) '--- write byte
tb=b
For i=0 To 7
SetPin clk,dout 'clk lo
If (tb And 1) Then 'set bit
SetPin dat,din
Else
SetPin dat,dout
EndIf
SetPin clk, din 'clk hi
tb= tb >> 1
Next i
SetPin clk, dout 'clk lo
SetPin dat, din 'release dat
'check ack here?
End Sub
Sub start '-------- start
SetPin dat,dout 'dat lo
End Sub
Sub stop '--- stop
SetPin dat, dout 'dat lo
SetPin clk, din ' clk hi '
SetPin dat, din ' dat hi
End Sub
Sub init '---- initialise TM1637
Pin(dat)=0
Pin(clk)=0
SetPin dat,din,pullup
SetPin clk,din,pullup
Dim dgt%(9)=(&H3F,&H06,&H5B,&H4F,&H66,&H6D,&H7D,&H07,&H7F,&H6F)
' ,&H77,&H7C,&H39,&H5E,&H79,&H71) 'A..F
' degree symbol is &H63, C is &H39
' colon - or 2nd digit with &H80
start 'reset, enab(8)+brightness
wrtb(&H80+8+7) '0=dim
stop
End Sub
Posted: 09:29pm 05 Jul 2024
If it's a case of the timing being fine but getting thr wrong segments then you have to be shifting them out incorrectly. Are you sending active low instead of active high or something? Possibly clocking twice at the beginning so it throws everything out by one segment?
palcal
Posted: 11:34pm 05 Jul 2024
Thanks for that Dave, it ran with minutes and seconds so I changed it to hours and minutes, working fine.
Peter's code runs for about a minute then dislays random numbers very fast and stops with the number 1993?
palcal
Posted: 10:59pm 06 Jul 2024
@DaveJacko
Still running Ok. Wondering if there is a reason you used
instead of
wrtb(dgt%(Val(Mid$(Time$,4,1))))
I tried to eliminate the leading zero but had no luck.
DaveJacko
Posted: 09:20pm 07 Jul 2024
probably because I still think in assembly language
also why I use the shrtst variable names I can
best regards !
Posted: 09:49pm 07 Jul 2024
nt a _prb
