Local Time 17:17 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GMT date etc from local time
zeitfest
Posted: 03:18pm 27 Jun 2024
I had a program that depended on GMT, and so to derive it I subtracted the time difference from local time from a RTC. But I forgot to ripple through the possible date/month/year changes that might  be needed.
So this is hopefully a trivial snip that does that.  Does it look OK? Clunky as, but
clunky is easier to revisit       ( Not worrying about daylight saving )
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
C
     PROGRAM gmtfromrtc
C
C     Reads RTC and calculates GMT
C
C     Input :
C     RTC time, offset
C
C     Time zone offset  is  Hours ahead of GMT
C     eg Sydney is 10.0.
C
C     Output : GMT
C
     INTEGER*4 day, mnth, year, hournt, min, sec
     INTEGER*4 mingmt, hrgmt, daygmt, mongmt, yeargmt
     INTEGER*1 zone, timevec(6), mnleng(12), yrem
C
C     Setup
C
C     Safe defaults
C
     day = 1
     mnth = 12
     year = 2015
     min = 0
     sec = 0
     hournt = 0
     zone = 10
C month length
     mnleng(1) = 31
     mnleng(2) = 28
     mnleng(3) = 31
     mnleng(4) = 30
     mnleng(5) = 31
     mnleng(6) = 30
     mnleng(7) = 31
     mnleng(8) = 31
     mnleng(9) = 30
     mnleng(10) = 31
     mnleng(11) = 30
     mnleng(12) = 31
     SYSRTC timevec
C local time from rtc
     day = timevec(1)
     mnth = timevec(2)
     year = timevec(3) + 2000
     hournt = timevec(4)
     min = timevec(5)
     sec = timevec(6)
C set february length for leap years 2001-2099
     yrem = year - ( year / 4 ) * 4
     IF ( yrem = 0 ) mnleng(2) = 29
C initial values
     mingmt = min
     hrgmt = hournt
     daygmt = day
     mongmt = mnth
     yeargmt = year
C Adjust hour and so day, month, year as necessary
     IF ( zone > 0 ) THEN
       hrgmt = hrgmt - zone
       IF ( hrgmt < 0 ) THEN
         hrgmt = hrgmt + 24
         daygmt = daygmt - 1
       END IF
       IF ( daygmt < 1 ) THEN
         mongmt = mongmt - 1
         IF (mongmt < 1) THEN
           mongmt = 12
           yeargmt = yeargmt - 1
         END IF
       daygmt = mnleng(mongmt)
       END IF
     END IF
     IF ( zone < 0 ) THEN
       hrgmt = hrgmt + zone
       IF ( hrgmt > 24 ) THEN
         hrgmt = hrgmt - 24
         daygmt = daygmt + 1
       END IF
       IF ( daygmt > mnleng(mongmt) ) THEN
         daygmt = 1
         mongmt = mongmt + 1
         IF (mongmt > 12) THEN
           mongmt = 1
           yeargmt = yeargmt + 1
         END IF
       END IF
     END IF
     PRINT *, "Time zone offset " , zone
     PRINT *, "Day, month, year"
     PRINT *, "Hour, min, sec"
     PRINT *,
     PRINT *, "Local time :"
     PRINT *, day," ", mnth," ",year
     PRINT *, hournt," ",min," ",sec
     PRINT *, "GMT is :"
     PRINT *, daygmt," ",mongmt," ",yeargmt
     PRINT *, hrgmt," ",mingmt," ",sec
     PRINT *, "Finish"
     END
with output :
Time zone offset 10
Day, month, year
Hour, min, sec
Local time :
28 6 2024
0 35 0
GMT is :
27 6 2024
14 35 0
Finish
Edited 2024-06-28 01:23 by zeitfest
Posted: 03:31pm 27 Jun 2024
Would it be easier to keep the RTC at UTC / GMT and then read TIME$ into LTIM$, modified for local time?
There is a routine in FotS to apply daylight savings time automatically once you have got local time sorted out.
Posted: 04:52pm 27 Jun 2024
Much easier using the epoch and datetime$ functions
a%=epoch(now)
a%=a%-10*60*60
b$=datetime$(a%)
Edited 2024-06-28 02:53 by matherp
Posted: 05:46pm 27 Jun 2024
... and in case you change your mind and do want to do DST, you need to know when to add it on... (easy tweak for your time zone)
IsDST()
run your clock in base time, then just adjust it when you want to display it.
Edited 2024-06-28 03:53 by CaptainBoing
zeitfest
Posted: 11:27pm 27 Jun 2024
Initially I was setting the RTC to GMT, but the reverse complication was needed when the clock had to be set / reset (which is too often during development for various reasons    ) and the local time display is useful. It has to be able to be reset by users with local time. (DST will be extra)
It isn't MMBasic.  Maybe I should add the epoch, datetime functions ... they won't be used much otherwise though.
zeitfest
Posted: 11:52pm 28 Jun 2024
Digging deeper--
Pre-C systems tended to return time values as an array, which is why I used a small array (timevec) to hold the time values from the RTC.
Glory be, the standard C time.h library has a function gmtime that returns Universal Time (historical GMT) !  Looks like structs are used for the data, that is sensible, I guess it follows the origins. Also there are utility functions for time differences and daylight saving.
The conventional way seems to be to convert the date/time and difference to seconds from the start of epoch, subtract, then reconvert back to date/time. So the ripple calculation above is done as part of that.
There is also the idea of using a date/time datatype, not justified here but it is used in say arduino etc.
