Local Time 12:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Best Fit Tiles into a Polygon
panky
Posted: 11:59pm 25 Jun 2024
Hi All,
I would like to have a program that can work out the best fit for a series of tiles into a defined polygon area without overlap of tiles or edges.
My requirement is to calculate the best fit for solar panels on a defined roof area.
Seems like a good candidate for MMBasic and sprites but I am a bit pushed for time at the moment. Has anyone on the forum done any work in this are?
Any advice or pointers would be appreciated.
Doug.
vegipete
Posted: 01:31am 26 Jun 2024
Google "nesting software"
Posted: 06:43am 26 Jun 2024
There are programs (not in MMBasic!) which are designed for exactly this purpose on the PC. I think they are free too. Virtually all solar panel installers use them, of course. :)  I know that at least one uses an aerial view from Google Maps. You draw the roof outline over the picture and run the program. It sorts out your panel positions.
