Local Time 17:28 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic functionality not as described in the doc
Posted: 09:28am 14 Jun 2024
Morning forum.
small heads-up.
I have just spent a while chasing down a tricky bug and it turns out due to the << and >> operators not doing what it says on the tin.
From the MicroMite manual:
Shift operators:
x << y x >> y These operate in a special way. << means that the value returned
will be the value of x shifted by y bits to the left while >> means the
same only right shifted. ... any bits
shifted off are discarded and any bits introduced are set to zero.
however, lost bits are clearly not shifted in as zeroes. Consider the following:
> dim n as integer
> n=1
> ?n<<63
-9223372036854775808     <-- as expected
> ?n<<64
1                       <-- huh? expected the one bit to get shifted away and return 0
> ?n<<65
2
> ?n>>64
1                      <-- works the other way too
so << and >> appear to be really rotates
easy enough work around (working with very large +/- integers might require more care) but hopefully this will lodge in your wet-ware and you won't get caught like I did.
It actually looks like the compiler directive isn't acting as (I) expected:
void op_shiftleft(void) {
   iret = (long long int)((unsigned long long int)iarg1 << (long long int)iarg2);
coz the outcome isn't a shift in the classic form... maybe you C proggers are totally aware of this
tried on an old MicroMite version and MMX 5.070105
h
Edited 2024-06-14 19:43 by CaptainBoing
Posted: 09:52am 14 Jun 2024
PicoMite and CMM2 both appear to be correct so could be a bug in the Microchip compiler
Edited 2024-06-14 20:00 by matherp
Posted: 09:59am 14 Jun 2024
cheers Pete. I am always reluctant to point the finger at an IDE but it is looking like it. In which case I am suspecting Thwills variant(s) and MMBasic for DOS will be OK too.
I always seem to find this obscure stuff that has never bothered anyone else in a 100 years
h
Edited 2024-06-14 20:15 by CaptainBoing
Posted: 12:11pm 14 Jun 2024
Latest MM2 version also.
> Micromite MKII MMBasic Ver 5.05.05
Copyright 2011-2021 Geoff Graham
ILI9488 driver loaded
> dim n as integer
> n=1
> ?n<<63
> ?n<<64
1
> ?n<<65
2
> ?n<<72
256
> ?n>>64
1
> ?n>>65
0
> ? n
1
Same on MM+ Ver 5.05.05
Making it visible
for n=64 to 80 step 8:cls 255<<n :pause 2000:next
Edited 2024-06-14 22:49 by phil99
Posted: 02:03pm 14 Jun 2024
Thanks guys.
I now have quite a collection of minor bugs so I can see that an update is now overdue.
zeitfest
Posted: 01:21am 15 Jun 2024
IIRC there was an obscure compiler/library  directive/options(s) that determined how the "new" bits  were set - I can't remember the details atm , something similar to erased memory bits being set by default
Edited 2024-06-15 11:29 by zeitfest
Posted: 04:29am 15 Jun 2024
it could also be that the compiler generates code (using pascal pseudocode) similar to:
result := X << (count mod 64)
this would make some sense, as the count parameter needs to be constrained in some way to protect against getting stuck in a pointless loop - assuming here that << at the most fundamental level decomposes down to a series of 1-bit shifts.
one fix would be to use the pseudocode:
if abs(count)>63 then result := 0
                else if count<0 then result := X >> -count
                                else result := X << count
this fixes things for both shifts of more than 63 bits and negative values of count.
but then is there anything fundamentally wrong with existing behavior? one could argue, on the principal of "garbage in, garbage out", that perhaps the user themself should be expected to check for what is effectively an overflow in the count parameter?
rob   :-)
Edited 2024-06-15 14:30 by robert.rozee
Posted: 08:56pm 15 Jun 2024
  robert.rozee said  ... decomposes down to a series of 1-bit shifts.
if the compiler uses the hardware efficiently, I think all 'mite CPU flavours contain a Barrel shifter
well, that thought sort of did occur to me - could it just be thought of as a rotate instead (it would split the platforms on the documentation Pico & CMM2 shift the examples correctly).
Having thought about this, I think your second example might be the fix. In each of the tests I did, the value I shifted - if you MOD 64 then shift, the answer is right... 1<<(64 mod 64) is 1<<0 which is one... like wise 65 is a <<1 which agan gives a two. So I think the compiler is doing that under the covers.
EDIT:
ok, tsting proves that is what is happening...
For n=0 To 80 Step 1:Print n,Bin$(15<<n,64):Next
50     0000000000111100000000000000000000000000000000000000000000000000
51     0000000001111000000000000000000000000000000000000000000000000000
52     0000000011110000000000000000000000000000000000000000000000000000
53     0000000111100000000000000000000000000000000000000000000000000000
54     0000001111000000000000000000000000000000000000000000000000000000
55     0000011110000000000000000000000000000000000000000000000000000000
56     0000111100000000000000000000000000000000000000000000000000000000
57     0001111000000000000000000000000000000000000000000000000000000000
58     0011110000000000000000000000000000000000000000000000000000000000
59     0111100000000000000000000000000000000000000000000000000000000000
60     1111000000000000000000000000000000000000000000000000000000000000
61     1110000000000000000000000000000000000000000000000000000000000000  <
62     1100000000000000000000000000000000000000000000000000000000000000  < should have low bits if it was rotate
63     1000000000000000000000000000000000000000000000000000000000000000  <
64     0000000000000000000000000000000000000000000000000000000000001111
65     0000000000000000000000000000000000000000000000000000000000011110
66     0000000000000000000000000000000000000000000000000000000000111100
67     0000000000000000000000000000000000000000000000000000000001111000
68     0000000000000000000000000000000000000000000000000000000011110000
69     0000000000000000000000000000000000000000000000000000000111100000
70     0000000000000000000000000000000000000000000000000000001111000000
h
Edited 2024-06-16 07:41 by CaptainBoing
Martin H.
Posted: 04:45am 16 Jun 2024
The maximum number of bits is 64, so a further shift is not possible. We are talking about a bit shift, not a rotation. Therefore, no overflow bits appear on the right side.
If you try to shift by 64 or more, an overflow occurs. This means that only the values from 0 to 63 are considered, and any bit positions beyond that are ignored. Therefore, the number is effectively taken modulo 64 (n AND 63).
 N      0100001
AND     0011111
=       0000001
Edited 2024-06-16 14:46 by Martin H.
'no comment
Posted: 09:44am 16 Jun 2024
I actually regret starting this whole thread now. Interesting canter though it is, it was a waste of time once the low-level method is understood.
I think things are working it's just that I expected an "over-range" shift to zero-out the register... at machine level (i.e. assembler) if I shifted one bit at a time, over-range, it would do precisely that, but the use of specialised hardware in the chip to do the shift possibly mandates some checks.
What we have here is the compiler making sure the shift is always in range. simple.
Geoff; I don't think this should be on the bug list - unless you want to throw an "out of bounds" error. But to be frank, now the functionality is well understood, why bother tweaking anything? - except for compatibility with the newer Mites - as Peter noted above the H7 and Pico handle over-range shifts differently.
h
Edited 2024-06-16 19:47 by CaptainBoing
Posted: 01:23pm 16 Jun 2024
  CaptainBoing said  Geoff; I don't think this should be on the bug list - unless you want to throw an "out of bounds" error. But to be frank, now the functionality is well understood, why bother tweaking anything? - except for compatibility with the newer Mites - as Peter noted above the H7 and Pico handle over-range shifts differently.
I have not tested the rotate operators recently.  But, when the code was originally written (many years ago), the shift worked as described in the manual - so I need to find out what is going on here.  Regardless, the result and the manual should agree, so one or the other should change.
Posted: 07:47pm 16 Jun 2024
probably just some wording change in the MicroMite manual would do;
Shift operators:
Note: that y is subject to MOD 64
something like that covers it I think (although my wording is dreadful)
h
Edited 2024-06-17 05:47 by CaptainBoing
