Local Time 12:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: "Brownian motion" sprite example
Posted: 11:56am 09 Jun 2024
Hi folks (which probably means Peter),
Just working on sprite support in MMB4L using the "Brownian motion" example: https://www.thebackshed.com/forum/ViewTopic.php?TID=14884#187117
However at the end of the main loop we have:
For i=1 To 64
 vector i, direction(i), 1, x(i), y(i)
 Sprite show i,x(i),y(i),1
  If sprite(S,i)<>-1 Then
    break_collision i
  EndIf
Next i
Except the SPRITE(S) sub-function isn't documented or implemented to take any additional arguments on either the PicoMiteVGA or CMM2.
What gives - other than MMBasic's "loose" error handling ?
Posted: 01:22pm 09 Jun 2024
Looks like a bug in the Basic program - should be
If sprite(C,S,i)<>-1 Then
and as you say additional parameters are not error-ed unless specifically coded for
Posted: 02:44pm 09 Jun 2024
Thanks Peter,
I'm going to go out on a limb and suggest you confused yourself and meant:
' If sprite i has any active collisions then ...
If Sprite(C, i) > 0 Then ...
Edited 2024-06-10 00:54 by thwill
