Local Time 12:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic Webmite 5.09 bug
jovian
Posted: 03:08am 08 Jun 2024
Hi all
Just wanted to report what appears to be a bug in webmite 5.09
This has been messing me up for days.. functions that run perfectly in main program but when library saved pull up errors. I have distilled the problem down to the following code. Once library saved, the function always gets truncated after the if...endif statement (regardless of what becomes before or after). Note there is no "next i" statement after library list all. I am finding that some functions are saving no problem and others are pulling up unexplainable errors. The length of the function is not a factor.
Can someone else replicate this behaviour?
library delete
> autosave
function dtn(d$)
   local excelStartYear=1900
   local i
   local deltaDays
   local ddd,mmm,yyy
   yyy=val(right$(d$,4))
   For i=excelStartYear To yyy-1
       If i Mod 4=0 and i Mod 100<>0 and i Mod 400<>0 Then
           deltaDays = deltaDays + 366
       Else
           deltaDays = deltaDays + 365
       End If
   next i
End function
Saved 352 bytes
> library save
Library Saved 232 bytes
> library list all
Function dtn(d$)
Local excelStartYear=1900
Local i
Local deltaDays
Local ddd,mmm,yyy
yyy=Val(Right$(d$,4))
If i Mod 4=0 And i Mod 100<>0 And i Mod 400<>0 Then
Else
End If
> ? mm.info(version)
5.09
Joe
jovian
Posted: 03:29am 08 Jun 2024
Comment out a few lines and the function saves fine:
> library delete
> autosave
function dtn(d$)
   local a
   local deltaDays
   local ddd,mmm,yyy
   For a=excelStartYear To yyy-1
'        If a Mod 4=0 and a Mod 100<>0 and a Mod 400<>0 Then
'            deltaDays=deltaDays+366
'        Else
'            deltaDays=deltaDays+365
'        End If
   next a
End function
Saved 367 bytes
> library save
Library Saved 132 bytes
> library list all
Function dtn(d$)
Local a
Local deltaDays
Local ddd,mmm,yyy
Next a
End Function
Rewrite the same few lines and the problem returns:
> library delete
> autosave
function dtn(d$)
   local a
   local sum
   local deltaDays
   local ddd,mmm,yyy
       sum=365
       if a Mod 400=0 Then sum=366
       If a Mod 4=0 Then
           if a Mod 100<>0 Then sum=366
       end if
       deltaDays=deltaDays+sum
   next a
End function
Saved 373 bytes
> library save
Library Saved 212 bytes
> library list all
Function dtn(d$)
Local a
Local sum
Local deltaDays
Local ddd,mmm,yyy
sum=365
If a Mod 400=0 Then sum=366
If a Mod 4=0 Then
If a Mod 100<>0 Then sum=366
End If :
Posted: 04:45am 08 Jun 2024
Perhaps "End If" is being read as "End"
Try "EndIf"
Removing the space might remove the confusion, though either should work.
jovian
Posted: 05:08am 08 Jun 2024
  phil99 said  Perhaps "End If" is being read as "End"
Try "EndIf"
UN. FREAKIN.BELIEVABLE
That worked.
So it IS a bug then! "End if" is not legit in the Library WTF!!?
Yes thank you Phil that has put me out of three solid days of absolute misery... I have always used "End If" without problem but only just started using the Library... this has thrown so many stupid errors at me I have aged.
Thanks 1000000
Joe
Posted: 07:45am 09 Jun 2024
Thanks for the report - will fix in RC6
jovian
Posted: 02:37am 11 Jun 2024
  matherp said  Thanks for the report - will fix in RC6
You are a star (and a genius). Thank you.
Is there a way to donate support$?
Posted: 07:35am 11 Jun 2024
You should find the problem is fixed in the RC5 update I posted yesterday. Please check and confirm.
The pleasure is in seeing you all use my/Geoff's code. Monetary recompense is not needed or a motivation.
jovian
Posted: 01:50am 14 Jun 2024
Hi Peter
I can only say thanks for your generosity, it is making the world a better place.
I have checked the RC5 update briefly, unfortunately nothing is running, here is a log:
WebMite MMBasic Version 5.09.00RC5
Copyright 2011-2024 Geoff Graham
Copyright 2016-2024 Peter Mather
> OPTION RESET PICO-RESTOUCH-LCD-3.5
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION COLOURCODE ON
OPTION CPUSPEED  252000 'KHz
OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13
OPTION TOUCH GP16,GP17
GUI CALIBRATE 0, 3963, 216, -1285, 859
OPTION SDCARD GP22
OPTION MODBUFF ENABLE  192
OPTION PLATFORM Pico-ResTouch-LCD-3.5
> autosave [code containing library being only functions and subroutines]
library save
>saved 3576 bytes
> autosave
?"hello"
Saved 18 bytes
> run
jovian
Posted: 02:00am 14 Jun 2024
  matherp said  You should find the problem is fixed in the RC5 update I posted yesterday. Please check and confirm.
Please scratch the above. User error. errant "end" in my functions.
Tried RC05 again.. all good! :-)
Joe
Edited 2024-06-14 12:15 by jovian
