Local Time 12:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : is there a list of error messages in mmbasic?
v.lenzer
Posted: 08:24am 04 Jun 2024
I only recently discovered the rp2040 zero and I enjoy programming with mmbasic. At the moment I'm trying to work on the gui controls (GUI BUTTON). I get the error message "gui reference number #1 in use". Sometimes it's a different number. What could be wrong? I haven't found anything (google, manual, this forum). "gui disable all" didn't help either. Can anyone give me a hint?
(I'm using version 5.08)
Edited 2024-06-04 18:36 by v.lenzer
Best wishes! Joachim
Posted: 08:35am 04 Jun 2024
When programming using the GUI controls each control has a reference number. That's used to work with that particular control.
If you define, say, a button you might use
GUI BUTTON #6, "Button" etc.
That is now control #6 and nothing else can use that number.
If you now define a LED using
GUI LED #6, "LED" etc.
you'll get the error "GUI reference #6 in use" because that reference number has  already been used.
v.lenzer
Posted: 08:49am 04 Jun 2024
Hello Mick!
Thank you for your answer. My program has a main menu with buttons. I use them to branch into different parts of the program. From the program parts, I want to use the "MENU" button to go back to the main menu. There, the command "GUI BUTTON #1 ....." is processed again and an error occurs. Obviously, I am not allowed to call the command a second time. But how can I display the buttons again?
Here is my source code. But be careful: It is in development and I am a beginner when it comes to RP2040 Zero and MMBasic. I am also trying out different techniques with it. Comments are german.
'PIO-Monitor V.1.0.  JM 5/2024
'PicoMite MMBasic Version 5.08.00
'OPTION SYSTEM SPI GP6,GP3,GP4
'OPTION LCDPANEL ILI9341, LANDSCAPE,GP7,GP2,GP5
'OPTION GUI CONTROLS 76
'OPTION TOUCH GP14,GP15
'GUI CALIBRATE 0, 133, 158, 898, 644
'COM 6
'to do:
'Datenlogger auf SD-Card
'Trigger?
setpin gp09,din
setpin gp10,din
setpin gp11,din
setpin gp12,din
setpin gp26,din
setpin gp27,din
setpin gp28,din
setpin gp29,din
DefineFont #8
'hi-lo-40x20.bas
' Font type    : Numeric (2 characters)
' Font start   : CHR$(48)
' Font size    : 40x20 pixels
' Memory usage : 204 bytes
 02301428
 00000000 00000000 00000100 00010000 00000000 00000000 00000000 00000100
 00010000 00000000 00000000 00000000 00000100 00010000 00000000 00000000
 00000000 FFFF0100 FFFFFFFF FFFFFFFF 00000000 00000000 00000100 00010000
 00000000 FFFFFFFF FFFFFFFC 00C0FDFF C00D0000 0C000000 000000C0 0000C00C
 00C00D00 C00D0000 0C000000 000000C0 0000C00C 00C00D00 C00D0000 0C000000
 000000C0 0000C00C 00C00D00 C00F0000 0F000000 00000000 00000000 00000100
 00010000 00000000
End DefineFont
const messen=1
const monitor=2
const d0=3
const d1=4
const d2=5
const d3=6
const d4=7
const d5=8
const d6=9
const d7=10
const menu=11
Menue:
bh=50    'button-Höhe
bw=240   'button-Weite
cls rgb(black)
font 5
gui button messen, "Messen",40,80,bw,bh, rgb(white),rgb(red)
gui button monitor, "Monitor",40,160,bw,bh, rgb(white),rgb(red)
do
if ctrlval(messen)=1 then goto zeitmessung
if ctrlval(monitor)=1 then goto monitor
loop
'Ausgabe horizontal binär, dezimal
monitor:
cls rgb(black)
x=0:y=60
menubutton
do
 p=port (gp09,4,gp26,4)
 d$=str$(port (gp09,4,gp26,4))
 if p < 10 then d$="00"+d$
 if p > 9 and p < 100 then d$="0"+d$
 font 8:text x,y,bin$(p,8)
 font 6:text x+100,y+60,d$+"      "
 loop until ctrlval(menu)=1
 goto menue
'Zeitmessung zwischen Flankenwechsel 0-1-0 oder 1-0-1
zeitmessung:
bh=60  'button-Höhe
bw=60  'button-Weite
r1=16  'äußerer Rand und mittlerer Abstand in x-Richtung
r2=20  'mittlerer Abstand in y-Richtung
font 5
cls rgb(black)
'Portauswahl D0 bis D7
x=r1:y=r1
gui button d0, "D0", x,y,bw,bh, rgb(white),rgb(red)
x=x+r1+bw
gui button d1, "D1", x,y,bw,bh, rgb(white),rgb(red)
x=x+r1+bw
gui button d2, "D2", x,y,bw,bh, rgb(white),rgb(red)
x=x+r1+bw
gui button d3, "D3", x,y,bw,bh, rgb(white),rgb(red)
x=r1:y=r1+r2+bh
gui button d4, "D4", x,y,bw,bh, rgb(white),rgb(red)
x=x+r1+bw
gui button d5, "D5", x,y,bw,bh, rgb(white),rgb(red)
x=x+r1+bw
gui button d6, "D6", x,y,bw,bh, rgb(white),rgb(red)
x=x+r1+bw
gui button d7, "D7", x,y,bw,bh, rgb(white),rgb(red)
menubutton
'Pin-Nr.-Zuweisung für Messung und GP-Zuweisung für Anzeige
do
if ctrlval(d0)=1 then p=12:g$="D0-GP9":goto messung
if ctrlval(d1)=1 then p=14:g$="D1-GP10":goto messung
if ctrlval(d2)=1 then p=15:g$="D2-GP11":goto messung
if ctrlval(d3)=1 then p=16:g$="D3-GP12":goto messung
if ctrlval(d4)=1 then p=31:g$="D4-GP26":goto messung
if ctrlval(d5)=1 then p=32:g$="D5-GP27":goto messung
if ctrlval(d6)=1 then p=34:g$="D6-GP28":goto messung
if ctrlval(d7)=1 then p=35:g$="D7-GP29":goto messung
if ctrlval(menu)=1 then goto menue
loop
Messung:
gui disable all
cls
a=pin(p)
t=0
do
loop until pin(p) <> a
do
t=t+1
loop until pin(p) = a
if a=1 then b=0
if a=0 then b=1
t=t*38316   'Dauer in nsec für einen Durchlauf t
font 5
text 10,20,"Port "+g$
text 10,80,"Dauer "
font 8:text 170,80,str$(a)+str$(b)+str$(a)
font 5
if t>=1000000 then text 10,140,str$((int(t/10000))/100)+" msec"
if t<1000000 then text 10,140,str$(t/1000)+" usec"
menubutton
do
goto auswahl
sub menubutton:
gui button menu,"Menu",210,170,100,60, rgb(white),rgb(red)
end sub
Posted: 10:16am 04 Jun 2024
I'm afraid you'll have to ask someone who uses the GUI controls more than I do. :) I've played with them but that's all.
v.lenzer
Posted: 11:38am 04 Jun 2024
I found a workaround: the menu button gets a different number in each part of the program. That works. It also works if I work with RUN instead of GOTO MENU, since the menu is at the beginning of the program. That's OK for me. That allows me to realize my planned projects. In the options I entered "option controls 75" :)
William Leue
Posted: 12:31pm 04 Jun 2024
Although you were asking about error codes that relate to GUI, here is my own strictly non-official list of MMBasic error codes. Also, note that you can always print out mm.errmsg$ to get a text explanation of an error.
' MMBASIC Error Codes -- non-official and likely partial list
const FR_OK               = 0 ' Succeeded
const FR_DISK_ERR         = 1 ' A hard error occurred in the low level disk I/O layer
const FR_INT_ERR          = 2 ' Assertion failed
const FR_NOT_READY        = 3 ' The physical drive cannot work
const FR_NO_FILE          = 4 ' Could not find the file
const FR_NO_PATH          = 5 ' Could not find the path
const FR_INVALID_NAME     = 6 ' The path name format is invalid
const FR_DENIED           = 7 ' Access denied due to prohibited access or directory full
const FR_EXIST            = 8 ' Access denied due to prohibited access
const FR_INVALID_OBJECT   = 9 ' The file/directory object is invalid
const FR_WRITE_PROTECTED  = 10 ' The physical drive is write protected
const FR_INVALID_DRIVE    = 11 ' The logical drive number is invalid
const FR_NOT_ENABLED      = 12 ' The volume has no work area
const FR_NO_FILESYSTEM    = 13 ' There is no valid FAT volume
const FR_MKFS_ABORTED     = 14 ' The f_mkfs() aborted due to any problem
const FR_TIMEOUT          = 15 ' Could not get a grant to access the volume within defined period
const FR_LOCKED           = 16 ' The operation is rejected according to the file sharing policy
const FR_NOT_ENOUGH_CORE  = 17 ' LFN working buffer could not be allocated
const FR_TOO_MANY_OPEN_FILES = 18 ' Number of open files > FF_FS_LOCK
const FR_INVALID_PARAMETER = 19 ' Given parameter is invalid
-Bill
Posted: 01:28pm 04 Jun 2024
I'm pretty familiar with the firmware C source now and my understanding is that:
To the first (and second, third, fourth ...) approximation MMBasic does not have meaningful error codes/numbers other than Mm.ErrNo <> 0 is an error; the contents of Mm.ErrMsg$ are generally useful though.
The codes that Bill quotes above are specific to errors in the third-party "Generic FAT Filesystem Module" which I believe is used by the CMM2 and the PicoMite "B:" drive (but not the PicoMite "A:" drive).
In general if there is an error then Mm.ErrNo = 16, this value is hard-coded into MMBasic's central C error() function. Why *16*, I've no idea, probably some historical legacy.
I'm trying to do better for MMB4L, but that's a work in progress and the list of error codes is very far from stabilising.
Edited 2024-06-04 23:30 by thwill
PhenixRising
Posted: 03:51pm 04 Jun 2024
Disclaimer: I'm clueless about MM GUI stuff.
However, I do graphics programming on Android and this strikes me that the GUI BUTTON is being repeatedly defined but with the same handle.
A quick check of the manual shows that the button is defined one time and from then-on, only the handle is referenced.
GUI CAPTION #1, "Speed (rpm)", 200, 50 ' label the number box
GUI NUMBERBOX #2, 200, 100, 150, 40 ' define and draw the number box
CtrlVal(#2) = 100 ' default value for the speed
GUI BUTTON #3, "RUN", 200, 350, 0, RGB(red) ' define and draw the RUN button
DO ' this runs in a loop forever
IF CtrlVal(#3)<10 OR CtrlVal(#3)>200 THEN ' check the speed setting
GUI DISABLE #3 ' disable RUN if it is invalid
ELSE ' otherwise
GUI ENABLE #3 ' enable the RUN button
ENDIF
IF CtrlVal(#3) = 1 THEN ' if the button is pressed
SetMotorSpeed CtrlVal(#2) ' make the motor run
ELSE ' otherwise the button is up
SetMotorSpeed 0 ' therefore set motor speed to zero
ENDIF
LOOP
v.lenzer
Posted: 05:49pm 04 Jun 2024
Thank you very much for your answers and tips.
I tried to test the example program. It is full of errors. The author has certainly never run it. The definition of GUI BUTTON #3, for example, is wrong and incomplete. The query ctrlval(#3) should be ctrlval(#2). I then stopped trying.
I will try to solve my problem with GUI ENABLE and GUI DISABLE. But I expect much more from the GUI SETUP Nbr. command that I came across in the manual. I have to get used to programming in an object-oriented way. Up until now, my input buttons were buttons on a circuit board. I am now testing the options mentioned and will report back. Hopefully with a successful report. Until then, best wishes! Joachim
Edited 2024-06-05 03:53 by v.lenzer
v.lenzer
Posted: 06:56am 05 Jun 2024
I think I have found the solution:
I first defined the screens with the buttons. To do this, I used the GUI SETUP nbr command. In the rest of the program, the various screens with the buttons are then called up with the GUI PAGE nbr command. You can also combine screens with one command. For example, I defined a screen (#3) that has the MENU button at the bottom right. Another screen has the port pins for selection (#1). With the GUI PAGE #1, #3 command, I can now display the buttons with the port pins together with the menu button. An error message no longer occurs.
Edited 2024-06-05 16:58 by v.lenzer
