Local Time 12:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Res Touch LCD SD Card issue
jovian
Posted: 12:01pm 03 Jun 2024
Hi all
I'm working on a project using the Pico Res Touch board. Webmite 5.08
I'm trying to access an SD card.
I have a FAT32 card inserted.
Options are set as manufacturer has specified.
OPTION LIST returns SDCARD GP22, GP5, GP18, GP19
all correct afaict
However...
PRINT MM.INFO$(SDCARD) returns
Not Present
I've checked, double checked and triple checked the configuration using option list, checked the card format (FAT32), card works in another machine, tried rebooting, power cycling, option resetting... to no avail.
Is this supposed to just... work, or am I perhaps missing something?
Thanks in advance
Joe
Posted: 12:36pm 03 Jun 2024
If you are using the latest firmware try
OPTION RESET PICO-RESTOUCH-LCD-3.5
or
OPTION RESET PICO-RESTOUCH-LCD-2.8
as applicable. This will set up the card correctly - just tested
jovian
Posted: 12:43pm 03 Jun 2024
Thanks Matherp
I tried it - the command was accepted
SDCard not configured error still.
and upon receiving CLS command,
Display not Configured
Option List returns:
WebMite MMBasic Version 5.08.00
Posted: 01:05pm 03 Jun 2024
  Quote  If you are using the latest firmware try
jovian
Posted: 01:33pm 05 Jun 2024
Hi Matherp
I did not realise the 5.09 beta was available. I upgraded my webmite, used your resTouch option recommendation and accessed the SD card first time.
Thanks once again for your help!
J
