Local Time 17:56 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite and Pico-GPS-L76B and MMBasic 5.09.00RC3
homa
Posted: 11:08am 01 Jun 2024
Referring to this thread https://www.thebackshed.com/forum/ViewTopic.php?TID=16915
and the question about a GPS module and the answer from Peter, I have purchased this recommended module.
A few questions directly.
I only use the “PiPico” and version 5.09.00RC3.
> option list
PicoMite MMBasic Version 5.09.00RC3
OPTION COLORCODE ON
Here is my test program:
'GPS - Test v0.1
'OPEN comspec$ AS GPS [,timezone_offset] [,monitor]
''The sentences interpreted are GPRMC, GNRMC, GPGGA and GNGGA.
'The timezone_offset parameter is used to convert UTC as received from the
'GPS to the local timezone. If omitted the timezone will default to UTC. The
'timezone_offset can be a any number between -12 and 14 allowing the time to
'be set correctly even for the Chatham Islands in New Zealand (UTC +12:45).
'If the monitor parameter is set to 1 then all GPS input is directed to the
'console. This can be stopped by closing the GPS channel.
'PRINT #GPS, expre etcssion [[,; ]expression]
'Outputs a NMEA string to an opened GPS device. The string must start with a
'$ character and end with a * character. The checksum is automatically
'calculated and appended to the string together with the CR/LF characters.
'GPS()
'https://www.waveshare.com/wiki/Pico-GPS-L76B
'Modul: waveshare - Pico-GPS-L76B, GP0 Tx pin, GP1 Rx pin
Dim lat, long As float
Dim latg, latm, longg, longm As integer
Dim lats, longs As float
Dim latd$, longd$ As string
SetPin GP1, GP0, COM1
'Open "COM1:9600" As GPS,+2,1
Open "COM1:9600" As GPS,+2,0
Do While (GPS(valid)<>1) And (GPS(fix)<>1)
 If Inkey$="x" Then Exit Do
Loop
'Close GPS
Pause 500
'SetPin GP1, GP0, COM1
'Open "COM1:9600" As GPS,+1,0
  Print "GPS Valid:", GPS(valid)
  Print "GPS FIX:", GPS(FIX)
  Print GPS(DATE), GPS(TIME)
  Print "Satellites: ", GPS(SATELLITES)
  'https://de.wikipedia.org/wiki/Dilution_of_Precision
  Print "DOP (top 1.0 - bad 10.0):", GPS(DOP)
  'https://gibs.bkg.bund.de/geoid/gserlaeuter_g.php
  'https://de.wikipedia.org/wiki/Geoid
  Print "Altitude: ", GPS(ALTITUDE), "GEOID:", GPS(GEOID)
  Print "Speed:", GPS(SPEED)
  Print "Track:", GPS(TRACK)
  lat =GPS(LATITUDE)
  long=GPS(LONGITUDE)
  Print "Latitude: ", lat, "Longitude:", long
  If lat<0 Then
     lat=lat*-1
     latd$="S"
  Else
     latd$="N"
  EndIf
  If long<0 Then
     long=long*-1
     longd$="W"
  Else
     longd$="E"
  EndIf
  latg=Fix(lat)
  latm=Fix((lat-latg)*60)
  lats=(((lat-latg)*60)-latm)*60
  longg=Fix(long)
  longm=Fix((long-longg)*60)
  longs=(((long-longg)*60)-longm)*60
  Print ,,Str$(latg)+Chr$(176);
  Print ""+Str$(latm)+Chr$(39);
  Print ""+Str$(lats,2,2,"0")+Chr$(34)+latd$;
  Print ,,,Str$(longg)+Chr$(176);
  Print ""+Str$(longm)+Chr$(39);
  Print ""+Str$(longs,2,2,"0")+Chr$(34)+longd$
  Pause 1000
Loop
1) Unfortunately I can't close and reopen the interface to disable the monitor function.
[34] Open "COM1:9600" As GPS,+1,0
Error : Pins not set for COM1
@Peter: Is this a bug in 5.09.00RC3 or am I using it wrong?
2) What does the altitude refer to? At my location, the value should actually be different. Do I have to calculate the GEOID here?
3) Track: how is this information to be understood? A rotation of the antenna is recognized with a delay, but the value generally jumps back and forth wildly.
4) Can functions in the module, such as GPS mode, multi-satellite, refresh rate, etc. be read out or activated specifically? How do you use the command for this?
PRINT #GPS, expression[[,; ]expression] ... etc
Who has experience with this module? I am not yet so enthusiastic about the accuracy.
Matthias
