Local Time 13:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 2.42" SSD1309 with Pi Pico
asknik2022
Posted: 07:25pm 29 May 2024
I am trying to configure an ZJY_M242 2.42" OLED via SPI but have no idea if this is set as an SPI or IIC Mode
two unjumpered connections R3 and R5 (?IIC)
one jumpered connection R4 (?SPI)
Also there is no SSD1309 display listed in the manual so can i use SSD1306SPI
The pinouts are labeled
GND
VCC
SCL
SDA
RES
DC
CS
So which pins are SCK and SDI for SPI Setup
Do i need to use pull up/down resistors?
Posted: 11:01pm 29 May 2024
Interesting module, if pricy. I would say that SCL is SCK, and SDA is SDI.
But why not try it as I2C and use only 2 pins?
I've long wondered why there wasn't an I2C OLED with the same resolution as the .96-inch ones, but just with bigger pixels.
If this cost half as much, I'd buy some.
Posted: 08:47am 30 May 2024
It is unlikely that this display will work with the SSD1306 driver and it is far too expensive to buy one to develop a driver. If you want a large mono 128x64 display then the ST7920 is supported over SPI
Posted: 12:09pm 30 May 2024
  matherp said  If you want a large mono 128x64 display then the ST7920 is supported over SPI
Thanks for the suggestion, but if the choice is SPI, then the ILI9341s are larger, cheaper, have higher resolution, have full color range, and if desired, have touch (and SD card).
I2C mono only preferable (in certain instances) if the size is 2.2 inches or greater, and the cost is no more than about $3USD.
Maybe power utilization could be a factor--I'm powering a .96" OLED from an ESP32 pin--because it's convenient from a wiring standpoint.
cosmic frog
Posted: 12:29pm 30 May 2024
  matherp said  It is unlikely that this display will work with the SSD1306 driver and it is far too expensive to buy one to develop a driver. If you want a large mono 128x64 display then the ST7920 is supported over SPI
I wasn't aware of this display, but it looks interesting. How is it connected to SPI, it looks like a parallel connection to me?
Link To ST7920
Thanks.
Dave.
Posted: 12:56pm 30 May 2024
This seller includes some of the data-sheet which shows serial or parallel is selected with pin 15.
Scroll down to "view more" and click.
Posted: 01:04pm 30 May 2024
  Quote  How is it connected to SPI, it looks like a parallel connection to me?
See this thread for wiring
Edited 2024-05-30 23:07 by matherp
cosmic frog
Posted: 02:32pm 30 May 2024
Thanks for the info. I'll have a look at these.
Dave.
