Local Time 13:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WebMite Demo Problems
EDNEDN
Posted: 12:04am 24 May 2024
I just got a Pico-W in the mail and I figured I would load up the WebMite firmware and put the Humidity and Temperature web page code on it.   I got the web page to show on my browser but I'm getting 1000 for both Humidity and the Temperature.   And the documentation says that is what I will get if I don't have a DHT22 sensor connected.
I'm just curious.   Looking at the demo code it seems like the bit banging should be down on GP28 to match the circuit shown on the demo page.   Of course I tried that, but I'm still getting a temperature of 1000.
Does anybody have any ideas what I should check?    I'm wondering if I got sent a DHT-11 by accident?   Does anybody know if the initialization and command set are the same for the two parts?
WEB TCP INTERRUPT WebInterrupt
DO
 BITBANG HUMID GP15, CurrentTemp, CurrentHumid
 PAUSE 1000
LOOP
SUB WebInterrupt
LOCAL INTEGER a, p, t, b(4096/8)
FOR a = 1 To MM.INFO(MAX CONNECTIONS)
WEB TCP READ a, b()
p = LINSTR(b(), "GET")
t = LINSTR(b(), "HTTP")
If (p > 0) And (t > p) Then
WEB TRANSMIT PAGE a, "index.html"
ENDIF
NEXT a
END SUB
Edited 2024-05-24 10:19 by EDNEDN
Posted: 12:39am 24 May 2024
Try increasing the pause to 2000. DHT sensors won't wake up if the pause is too short.
If this is on a breadboard check continuity from the Pico pins to all the DHT pins. Verify that you have 3.3V at the DHT pins. You may also need a pullup resistor, 3.3kΩ to 10kΩ.
See "Measuring Humidity and Temperature" in the manual.
A DHT22 command line test using whatever pin you have it connected to:-
Do :Device Humid GP28, t, h :? t, h :pause 2000 :loop
And for a DHT11:-
Do :Device Humid GP28, t, h, 1 :? t, h :pause 2000 :loop
EDNEDN
Posted: 02:01am 24 May 2024
Increasing the Pause to 2000 or 2500 doesn't help.   The connections have the pins of the Dupont wire soldered into the Pico-W.  The other side of the Dupont wires are female and go to the circuit board the Alleged DHT-22 is on.
I'll do the pull up next and see if that helps...
PS.  I messed around a little with:
The syntax is off.  I don't know what you intended.  I'm going to try that in a program instead of in immediate mode.
Edited 2024-05-24 12:45 by EDNEDN
Posted: 02:45am 24 May 2024
What firmware version are you running?
In later versions, BITBANG has been changed to DEVICE
DEVICE HUMID is the same as BITBANG HUMID
If you think it might be a DHT11, se the manual for command syntax
  Quote  DEVICE HUMID pin, tVar, hVar [,DHT11]
If the optional DHT11 parameter is set to 1 then the command will use device timings suitable for that device.
Using a pullup is strongly recommended.
Posted: 04:24am 24 May 2024
For a DHT11 with PicoMite MMBasic Version 5.09.00RC3 this is the output when the command line test is pasted into TeraTerm
13      57
13      47
13      58
13      58
13      58
EDIT
If the DHT is on a module it will probably have a 10kΩ pullup.
Data pin = S
Ground = -
3.3v = middle
Edited 2024-05-24 14:36 by phil99
Posted: 09:11am 24 May 2024
doesn't really contribute to help solve your problem but I have to say you are on a hiding to nothing with these ghastly devices. Long term they really suffer with humidity mis-reading and getting them to talk is a chore.
I long ago washed my hands of DHT11/22s in favour of the HTU21 (I think there are updates too - it has been some time) for precisely the pain you are experiencing now. HTU21  is i2c and so much easier to talk to - I got it first time with some code published here (by, I think TassyJim or maybe PalCal?).
If you are not too committed...
Edited 2024-05-24 19:24 by CaptainBoing
EDNEDN
Posted: 02:22pm 24 May 2024
  TassyJim said  What firmware version are you running?
> print mm.ver
5.0707
Thank you for the information about the name change for the command.
That clears up a lot of the confusion I had.   I'm still at the BitBang nomenclature.
  TassyJim said
If you think it might be a DHT11, see the manual for command syntax
Score!   Changing the GP15 to GP28 and adding the  ",1" to the end of the line made it work.   Even though I specifically ordered a DHT-22 they decided to send me a DHT-11.   Oh Well...   I got the demo working!!!!
Understood!   It looks like they have two surface mount resistors on the back side of the board.   So that is probably OK now that the web page returns meaningful values.
Thanks Jim!!!
Edited 2024-05-25 00:24 by EDNEDN
EDNEDN
Posted: 02:31pm 24 May 2024
  phil99 said  For a DHT11 with PicoMite MMBasic Version 5.09.00RC3 this is the output when the command line test is pasted into TeraTerm
13      57
13      47
13      58
13      58
13      58
EDIT
Data pin = S
Ground = -
3.3v = middle
Thanks... I can now duplicate your suggestion.
  Quote  >
> do:bitbang humid gp28, t,h,1: ?t,h:pause 2000:loop
25     56
25     56
25     56
25     56
25     56
25     56
25     56
25     56
25     56
25     56
25     56
pwillard
Posted: 03:01pm 24 May 2024
Sadly, the DHT11's are so much worse than a DHT22 that they are not much better than you using your OWN senses to figure current Humidity and Temperature.  Honest, a guess is about as reliably accurate as the DHT11 sensor.
Nice to see you got it to function though.
I agree with using a different sensor, like the HTU21. I use them now myself.
Edited 2024-05-25 01:02 by pwillard
EDNEDN
Posted: 03:32pm 24 May 2024
  pwillard said  Sadly, the DHT11's are so much worse than a DHT22 that they are not much better than you using your OWN senses to figure current Humidity and Temperature.  Honest, a guess is about as reliably accurate as the DHT11 sensor.
Yes.   I understand.   I just wanted some working demo code.    I've re-ordered several more DHT-22's off of eBay.   So I'll be able to ditch the DHT-11's soon.
