Local Time 13:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 1$ Risc-V mini Computer with VGA
hhtg1968
Posted: 05:47am 20 May 2024
GeoffG and MatherP are trendsetters for the world...
https://olimex.wordpress.com/2024/05/15/meet-rvpc-the-world-lowest-cost-open-source-hardware-all-in-one-educational-risc-v-computer-with-vga-and-ps2-keyboard-which-will-be-available-for-diy-soldering-workshop-on-open-fest-in-sofia-this-year/
Posted: 06:56am 20 May 2024
They even based their PCB hardware on my Pico Stick design. ;)
I bet the board won't be 1 euro by the time it gets to the UK...
Posted: 07:03am 20 May 2024
16K flash and 2k RAM. Very clever to get it working in such a small package but completely useless?
hhtg1968
Posted: 07:44am 20 May 2024
to matherp:
you are right. for such a small system it would be better to use a vt100 connection instead of using vga.
Martin H.
Posted: 10:18am 20 May 2024
16K flash and 2k RAM?
so maybe ther could run something like ZX80 (8K ROM and 1 K Ram, just to have a comparison) on it
But the would have to be recompiled from Z80 to Risc-V
It would probably not be possible to translate the original ZX81 ROM (16k) to 16K Risc-V code
'no comment
Posted: 10:40am 20 May 2024
the designers must be getting a pretty good deal on their 3x sockets (VGA, PS/2, power) to be able to squeeze within a us$1.09 (1 euro) price limit.
what would a RP2040 chip + 2mb SPI flash + 3v3 regulator cost if purchasing in bulk? us$2? this is essentially all you need to run mmbasic with VGA output and a USB keyboard, and while you'd struggle to get parts kit + PCB below 3-4 dollars, you would get a whole load more bang-for-your-buck in return.
rob   :-)
Posted: 10:51am 20 May 2024
  Martin H. said  16K flash and 2k RAM?
so maybe the[y] could run something like ZX80 (8K ROM and 1K RAM, just to have a comparison) on it[,] but the would have to be recompiled from Z80 to Risc-V. It would probably not be possible to translate the original ZX81 ROM (16k) to 16K Risc-V code
4k ROM for ZX80, 8k for ZX81; the spectrum had 16k of ROM.
a translation of the ZX80 ROM has (with a 40% size increase) been shoehorned into 8k of flash and run on an atmega8, see:
https://www.breatharian.eu/hw/atx80/index_en.html
rob   :-)
Martin H.
Posted: 11:15am 20 May 2024
rob   :-)
Thank you Rob, for the correction.
I couldn't do it anyway, since I wrote some Z80 assembler a long time ago, but have no idea about RISK V. And even if one do, what are you supposed to do with a 2KB ZX81? Except to show as technical demo, that it works.
Martin
'no comment
