Local Time 12:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 74HC14 question for the experts
PhenixRising
Posted: 10:23am 16 May 2024
I want to square-up my encoder signals with this Schmitt trigger which is 3.3V compatible.
This device features clamping diodes and can accept my 5v encoder signals via current-limiting resistors. Max input clamping current is 20mA per the datasheet. Therefore, I'm wondering; 1K or 10K resistors on my 5v signals?
74HC14.pdf
Posted: 10:37am 16 May 2024
Phenix,
Voltage dividers. Don't rely on the clamping diodes. Remember that the current pushed into the clamping diodes ends up in the power rails. And these do not have protection, only the current drawn by the chips can absorb this energy. Typically this is enough, but that depends on the amount of current, and the number of inputs, and if there is a sleep mode for chips (no current consumption)
Simply use a 1k/2.2k divider to get from 5V to 3.3V levels.
PhenixRising
Posted: 10:52am 16 May 2024
Oh sure but I use TH resistors and want to keep this board to the bare minimum. I figured that because this is a stated feature, I could use it:
Posted: 11:10am 16 May 2024
note from the datasheet:"Input Clamp Current ... ±20 mA"
so 1K would be fine, but to save a bit of juice I'd go higher. it's a CMOS input so not terribly low impedance beyond the clamp anyway, we are only sparing the diodes.
Whereas Harm's reply above is perfectly valid, in the interests of reducing the component count I would use a 4K7 in series with the inputs.
Excess voltage into each input (assuming 5V with Vcc=3.3) would be 1.7v, under 4K7 is around 360uA so even if all six inverters are used, it will dump just 2mA into Vcc across the whole chip. I wouldn't lose sleep over that. I would use whatever resistor 2K2 - 10K I had most of
Edited 2024-05-16 22:09 by CaptainBoing
PhenixRising
Posted: 12:44pm 16 May 2024
Great to see you posting again, Cap'n
Just so happens that 2K2, 4K7, 10K are the ones that I have ridiculous quantities of
Posted: 01:08pm 16 May 2024
cheers Phenix.
PeterB
Posted: 02:09am 17 May 2024
G'Day you lot.
High value R's will give slow rise & fall times which may or may not matter. Other than that, the higher the value the better until input impedance matters.
A slow rise / fall time can be corrected with speed up c's but that way lies madness.
I should stay out of these things but Capt. inspires me  😊
Petee
PhenixRising
Posted: 05:21am 17 May 2024
  PeterB said  G'Day you lot.
Petee
Yeah, signal is more important than board real-estate...Divider it is
Posted: 08:17am 17 May 2024
  PeterB said
... but Capt. inspires me
oh dear.There's probably some voluntary organisation that can help you rehabilitate
PeterB
Posted: 08:42am 17 May 2024
Capt.
Probably not.
Thirty years ago I decided to give up smoking, that was easy compared to staying out of the shed. The problems I have now are housework, lack of energy, brain decay I forget what else. And when I look at the shed I have no idea what people are talking about but once in a while an interesting topic like this one comes up and I remember the fun we had in the past. I wonder if PaulL is still hanging around out there with his particular brand of humor.
Stick with it.
Peter😘
Posted: 02:19pm 17 May 2024
yes it keeps me sane. Prob is, I lose stuff... I have a bee in my bonnet about my "sensible cartesian co-ordinates" graphic pack, and I want to finally get round to adding the ORIGIN sub... can I find my F4s? I have two of these beasts but they aren't where I thought... so this weekend - the hunt is on.
PeterB
Posted: 08:49am 31 May 2024
So, did you find it / them? Just to indicate where I am at, I've got no idea what you are talking about, but then I probably never did but you are at least still trying, Keep it up for as long as you can. I keep finding things and wonder what it is. perhaps an F4 who knows?
Peter
Edited 2024-05-31 18:50 by PeterB
Posted: 10:43am 31 May 2024
Hey Peter
sadly no. They have formally been assigned upgraded status from "mislaid" to "lost". it really irks me... I was convinced they would be with the others... went straight to my MMXs and H7 and plethora of smaller MMs. F4 & H7 are ST based "megamites". H7 is almost half a gig clock   - monster. same cpu as in the CMM2. F4 is the same architecture, different peripherals and 300Mhz clock - not to be sneered at. Both have a nice LCD backpack and are excellent dev platforms for screen based stuff.
I had a bit of a mare of Saturday, everything I touched turned to mud Subsequently I have a big repair to do which resulted in some re-design - so overall it was a "fun" experience... bit of thought, new PCB...
personally, I am still in the "ignore the b'stard" stage... good days & bad,but meh. I seem to have re-found my mojo a bit for the shed.
you?
Edited 2024-05-31 20:53 by CaptainBoing
PeterB
Posted: 12:20pm 31 May 2024
I decided some time ago that it was too difficult, so I offered my picos to anybody in the shed.
That resulted in me putting 3 picos plus a couple of other bits in a bag and sending them to Victoria. Unfortunately, the picos got lost so I ordered 3 more to be sent. That caused a lot of confusion, but it finished up OK. Then I got cross with myself for giving up so I ordered 3 more. I have played with them a bit but mostly they just sit on the desk and make me feel guilty. I still have other bits and there is a lot of work I could be doing for a mate but,,,,,,,,,,,,,,,,,,,,,,,
Peter
Posted: 12:27pm 31 May 2024
Peter,
PicoMite is great. But you should not feel guilty they are lying on the desk.
Though I think the bare pico is not as attractive to pick up, as a pico in a unit.
You may get more energy if you build one Pico into a unit. And that can easily be veroboard. On the forum I have recently seen boxes with a pico in it and nothing but flying wires, connectors.
I have no idea what your "projects" are, but I always grab my PicoMiteVGA unit, even if I don't use VGA or PS2 keyboard, simply because it is a stable "brick" that I know works. It can survive a drop off the table, and has the basics (i.e. SD card) installed. My "work horse". And MMEdit. Without MMEdit I would not be able to write code longer than 10k.
Edited 2024-05-31 22:34 by Volhout
PeterB
Posted: 12:49pm 31 May 2024
G"day Volhout
I have always needed a "real project". Fortunately I have / had mates in farming and engineering and since I retired, these people have kept me busy with touch screens via Grogster and smaller screens to control things like bait spreaders. It has been fun but several things happened to cause complications. COVID stopped the supply of some chips and the pico meant a new learning curve. It is very frustrating because I have the time. I can afford it and the need is there. Sadly I am 86 and my brain is also. My wife passed away in 2022 after 3 years in a nursing home. I then got friendly with the girl (87) over the back fence but the pain in her arm turned out to be cancer but we had a good (short) year and so it goes. She passed away last November.
The good thing is, it is raining
Posted: 01:10pm 31 May 2024
very sorry to hear that.
having a project is always the kicker; the ability is there, the will is there, just nothing to aim it at.
Posted: 09:25pm 31 May 2024
  PeterB said  I have always needed a "real project".
I have far too many 'real' projects waiting to be started, and a few more waiting to be finished.
My fingers no longer do what my brain tells them to do so I have had to abandoned many of the projects.
I have decided to have a shed clean-out and the list of 'stuff' looking for a new home is growing exponentially.
I will keep enough to keep me amused for a few years.
PeterB
Posted: 12:20am 01 Jun 2024
Good morning Jim.
My idea of a "real project" is when I am asked to make a device to do something.
The first part is to determine what they really need and then modify it as we learn more. The final product almost never looks like the initial request and that is the good bit. I have never charged for my work so that has made me reasonably popular. The Bait Spreader project went on for years and is now in good shape but when I look back at where it started, WOW.
I wouldn't have missed it for quids.
Peter
Posted: 12:57am 01 Jun 2024
Hi Peter,
When I worked for CSIRO, the scientists would come to the workshop with a journal from another country and ask me to make the equipment they were using. The articles were never in English so it was interesting.
I soon learnt that they didn't really want the 'same' just similar to do something different.
After that, I would sit them down and demand to know what they were trying to achieve.
Then I could make a piece of equipment that worked.
Interesting times.
A long time ago
