Local Time 00:04 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Checking for Sprites being hidden or displayed?
MarkF
Posted: 06:19am 16 May 2024
Hi all. Is there any command that allows to check if a sprite is hidden or being displayed?
I have a complex graphic screen with multiple sprites moving around.
Occasionally, my program will unexpectedly exit with an "sprite already hidden" error.
It would be great to check if a sprite is already hidden, before executing the Sprite hide command.
Posted: 07:10am 16 May 2024
Hi MarkF,
I don't know of any command that you can use for this purpose.
Since sprites do not hide autonomously, it is the code that hides the sprite.
So keep track of the sprites visibility in an array "visible%(nbr_of_sprites)".
When writing a sprite, set the cell to 1, when hiding it, set the cell to 0.
Posted: 07:48am 16 May 2024
You can use the sprite function with X or Y. They return 10000 if the sprite is not being displayed
Edited 2024-05-16 19:18 by matherp
MarkF
Posted: 12:59am 17 May 2024
Thank you Volhout and Mather for your recommendations.
As you mentioned this is a good solution....
SPRITE(X, [#]n)
Returns the X-coordinate of sprite n. This function is only active when the
sprite is currently displayed (active). Returns 10000 otherwise.
