Local Time 13:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Teraterm filename change
Chrisk
Posted: 02:39am 15 May 2024
Hi all
Can I change the filename of a file stored on the SD card using Teraterm and what is the syntax if possible.
Ta
Chris K
Posted: 03:19am 15 May 2024
  Manual, commands said  RENAME old$ AS new$
Rename a file or a directory from ‘old$’ to ‘new$’. Both are strings.
A directory path can be used in both 'old$' and 'new$'. If the paths differ the
file specified in 'old$' will be moved to the path specified in 'new$' with the
file name as specified.
Posted: 06:55pm 15 May 2024
on picomite....
Chrisk
Posted: 07:10am 16 May 2024
Thanks guys
