Local Time 13:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic on a RISC-V Processor?
grumpyoldgeek
Posted: 12:15am 07 May 2024
Specifically the CH32V303RCT6?  I'd love to design some hardware for it.
https://www.wch-ic.com/products/CH32V303.html?
Edited 2024-05-07 10:16 by grumpyoldgeek
Posted: 07:10am 07 May 2024
Too short of RAM and Flash to do anything very interesting. MM2 firmware with MM+ I/O is about all you could achieve. No advantage at all over something like the cheap STM32F407 with the ArmmiteF4 firmware
Posted: 07:47am 07 May 2024
  matherp said  No advantage at all over something like the cheap STM32F407 with the ArmmiteF4 firmware
Which is tried, tested, supported (bug fixes etc) & works really well :)
grumpyoldgeek
Posted: 04:16pm 07 May 2024
  matherp said  Too short of RAM and Flash to do anything very interesting. MM2 firmware with MM+ I/O is about all you could achieve. No advantage at all over something like the cheap STM32F407 with the ArmmiteF4 firmware
The CH32V303RCT6 is under 1 USD on Aliexpress.  The STM32F407 is about 11 USD on Digikey.  In any case, thanks for replying.
Posted: 05:59pm 07 May 2024
STM32F407 £1.4 on Aliexpress if you compare like with like supply for a much more powerful chip (RAM, FLASH, clock)
Edited 2024-05-08 04:02 by matherp
grumpyoldgeek
Posted: 06:53pm 07 May 2024
  matherp said  STM32F407 £1.4 on Aliexpress if you compare like with like supply for a much more powerful chip (RAM, FLASH, clock)
I'll take a look. Thanks.
