Local Time 13:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Long string on a PicoMite
Posted: 08:42am 06 May 2024
I'm sure this has been covered before, but searching was hopless ( maybe I should fix that ).
Long string on the PicoMite. I did find the C subroutines for longer string uploaded by matherp, but these didnt work on the Pico ( memory invalid address errors ).
Is there an alternative or a library, or is it just a case of breaking a stream of string data into small chunks and processing them that way?
Its for reading NMEA gps data, I need a bit more functionality than the built in GPS functions in PicoMite.
Edited 2024-05-06 19:03 by Gizmo
Posted: 08:53am 06 May 2024
Check the manual for the LONGSTRING commands and functions. The CSUBs you reference are all built-in as fully worked commands
Posted: 08:54am 06 May 2024
Hi Glenn,
I may be misunderstanding the question but the PicoMite has LONGSTRING support built in (equivalent to the old C subroutines), RTFM as it were .
Snap .
Posted: 09:14am 06 May 2024
Argh!
Thanks.
Posted: 09:18am 06 May 2024
Picomite is a miracle..
