Forum Index : Microcontroller and PC projects : Recommendations for GPS Modules
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1051 |
What are the recommendations for GPS modules that can be used with MM platforms? 0A47 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11883 |
For the Pico |
Thankyou Peter, is there a more generic module that I can use across the board of mites ? 0A47 |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6120 |
Nice module, Watch out, it uses a rechargeable cell. Not a CR1220 lithium battery. Volhout PicomiteVGA PETSCII ROBOTS |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
Neo6 or 7 GPS modules usually have standard 9600 baud TTL serial comms that you can parse for the 'Mites without the GPS functions in the firmware. EG Edited 2024-04-28 21:27 by phil99 |
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052 |
I usually use these GPS Or these GPS Edited 2024-04-29 06:48 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Thanks Palcal, I have lodged an order for some modules. 0A47 |
| grumpyoldgeek Regular Member Joined: 30/07/2018 Location: United StatesPosts: 58 |
I agree. I particularly like the VK2828U8G5LF because it has the 1pps signal that makes a nice interrupt. |
| Octatron Newbie Joined: 01/04/2015 Location: United KingdomPosts: 29 |
I looked at Palcal's GPS module recommendations and the first one was £2.98 to the UK and I thought great I may buy one of those until I noticed the postage £25.40!!! May be not. |
Make sure you are looking at the UK version of the AE site. Search by the type number. Buy 2 at £4.45 each and get free shipping. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
@ grumpyoldgeek and others, I have 2 VK2828U8G5LF modules, that is with the U8 and not U7, they worked with the GPS function on a Picomite but would not work with a Micromite. I found that they don't work if you use $GPRMC or $GPGGA they use $GNRMC and $GNGGA. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
