Local Time 13:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DAY OF WEEK ERRORS
OA47
Posted: 01:19am 09 Apr 2024
I have copied a formula from the web to get the day of week from the date. The code is giving me a zero response (Sunday) can anyone see where I have made the error?
Sub  GetDayOfWeek
 D=Val(Left$(Date$,2))
 M=Val(Mid$(Date$,4,2))
 C=Val(Mid$(Date$,7,2))
 Y=Val(Mid$(Date$,9,2))
 W=(D+(2.6*M-0.2)-2*C+Y+Y/4+C/4) Mod 7
Return
0A47
palcal
Posted: 01:36am 09 Apr 2024
Have a look in Fruit of the Shed there is a function in there for it.
morgs67
Posted: 03:01am 09 Apr 2024
This is what I use- (could be a bit wordy!)
'Tomohiko Sakamoto's Algorithm - lookup table
Dim integer MonthLookup(11) = (0,3,2,5,0,3,5,1,4,6,2,4)
Dim MonthNames$(11) = ("January","February","March","April","May","June","July","August","September","October","November","December")
'Tomohiko Sakamoto's Algorithm - dayname lookup table
Dim DayNames$(6) = ("Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday")
' Tomohiko Sakamoto's Algorithm- Finding the day of the week
Function DayOfWeek$(d,m,y)
 Local dow = 0
 LOCAL am = m
 LOCAL ay = y
 'if month is less than 3 reduce year by 1
 if am<3 then ay = ay-1
 dow = (ay + (ay\4) - (ay\100) + (ay\400) + MonthLookup(am-1)+d)MOD 7
 DayOfWeek$ = DayNames$(dow)
End Function
Good for the Georgian calendar.
Tony
Footnote added 2024-04-09 13:20 by morgs67
@palcal Would that be Gregorian.  -ooops spellcheck
palcal
Posted: 03:14am 09 Apr 2024
  Quote  Good for the Georgian calendar.
Posted: 03:21am 09 Apr 2024
Depending on the version of MMBasic this may be a little shorter:-
> date$="09-04-2024"
> ? DAY$(date$)
Tuesday
@OA47 in your first post see if changing "Return" to "End Sub" makes any difference.
Edit. No, just the same.
  Quote  > GetDayOfWeek : ? date$,D,M,Y,W
09-04-2024       9       4       24      0
Edited 2024-04-09 13:35 by phil99
OA47
Posted: 03:52am 09 Apr 2024
Thanks Phil, I had not caught up with DAY$(DATE$) and that works perfectly as I am using mm.ver=5.070725 in this project.
Changing RETURN to End Sub did not change the result, it must have been an old programmers Freudian slip.
0A47
Posted: 04:00am 09 Apr 2024
With a minor change the Sub seems to work.
>date$="01-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
01-04-2024       1       4       24      1      Monday
> date$="02-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
02-04-2024       2       4       24      2      Tuesday
> date$="03-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
03-04-2024       3       4       24      3      Wednesday
> date$="04-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
04-04-2024       4       4       24      4      Thursday
> date$="05-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
05-04-2024       5       4       24      5      Friday
> date$="06-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
06-04-2024       6       4       24      6      Saturday
> date$="07-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
07-04-2024       7       4       24      0      Sunday
> date$="08-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
08-04-2024       8       4       24      1      Monday
> date$="09-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
09-04-2024       9       4       24      2      Tuesday
> date$="10-04-2024" : GetDayOfWeek : ? date$,D,M,Y,W, DAY$(date$)
10-04-2024       10      4       24      3      Wednesday
> LIST
Sub  GetDayOfWeek
W=(D+(2.6*M-0.2)-2*C+Y+Y/4+C/4 +2) Mod 7
End Sub
OA47
Posted: 04:22am 09 Apr 2024
Phil, I am not sure why the addition of 2 makes it work but well done.
0A47
Posted: 04:45am 09 Apr 2024
By chance it happened to produce 0 on Tuesday and 1 om Wednesday so added an offset.
paceman
Posted: 05:18am 09 Apr 2024
Here's one from "Microblocks" who was a quite prolific and very capable TBS member for a number of years. Unfortunately he is no longer with us.
It looks a bit long but there's a lot of padding there that can be shortened.
Sub dayndate        'day-of-week code thanks to "MicroBlocks" at TBS forum.
 Local integer year,month,day,dayofweek,a,m,y
 Local string DOW$(6) length 3 = ("Sun","Mon","Tue","Wed","Thu","Fri","Sat")
 Local string dispdayndate$
 curdate$ = Date$
 Year=Val(Mid$(curdate$,7,4))
 Month=Val(Mid$(curdate$,4,2))
 Day=Val(Mid$(curdate$,1,2))
 a = Int((14-month)/12)
 m = month + 12*a - 2
 y = year - a
 DayOfWeek = (day+y+Int(y/4)-Int(y/100)+Int(y/400)+Int(31*m/12))Mod 7
 dispdayndate$ = DOW$(DayOfWeek)+" "+curdate$
 Text MM.HRes/2,MM.VRes-MM.Info(FONTHEIGHT),dispdayndate$,CB
End Sub
Greg
OA47
Posted: 05:26am 09 Apr 2024
Greg, years ago I was in regular contact with Microblocks we had a good trade happening, I would supply him with electronic magazines and he could source the 28 pin micromites from just around the corner from where he lived. IIRC his christian name was Jean.
0A47
Posted: 05:37am 09 Apr 2024
This one:- W=(D+(2.6*M-0.2)-2*C+Y+Y/4+C/4 +2) Mod 7
ignores the century and 4 century corrections.
This one:- DayOfWeek = (day+y+Int(y/4)-Int(y/100)+Int(y/400)+Int(31*m/12))Mod 7
ignores the 16 century correction next due in 3200.
Keep an eye out for that ;-)
Quazee137
Posted: 08:14am 09 Apr 2024
Here's what I've used for some time. Works going forward in time.
Function dow(d As Integer,m As Integer,y As Integer) As Integer
'  1       2       3       4       5       6       7
' sun     mon     tue     wed     the     fri     sat
  If m < 3 Then
     m=m + 12
     y=y-1
  End If
  dow = 1 + (d + ((26 * m+1)/10) - (2 * (y\100)) + y + (y\4) + (y\400) ) Mod 7
End Function
Posted: 02:10pm 09 Apr 2024
As hinted before:
print day$(date$)
paceman
Posted: 02:59am 10 Apr 2024
  OA47 said  Greg, years ago I was in regular contact with Microblocks we had a good trade happening, I would supply him with electronic magazines and he could source the 28 pin micromites from just around the corner from where he lived. IIRC his christian name was Jean.
Graeme - yes I knew he was Jean, and he was pretty young when he passed away. He helped me with some programming stuff and helped a lot more Thai students with his electronics school where he was living in Thailand.
Greg
OA47
Posted: 05:08am 10 Apr 2024
  Quote  Graeme - yes I knew he was Jean, and he was pretty young when he passed away. He helped me with some programming stuff and helped a lot more Thai students with his electronics school where he was living in Thailand.
Greg
It seems his Microblcks username is still registered in the member list but his original TZadvantage no longer exists.
0A47
