Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Driver for lcd panel using ST7789 controller
morgs67
Posted: 01:34pm 03 Apr 2024
Purchased a LCD display marked 2.4" TFT SPI 240X320 v1.3. It is almost identical to the red board shown in the picomite manual headed "Example SPI LCD Panel Configuration". However, it does not use a ILI9341 controller. With the ILI9341 driver the display is in portrait mode with part of the screen unused.
Tried several other drivers with no luck. Then found the ST7789_320 driver almost works.
The orientation needs to be set to Reverse Landscape. But all the colours are inverted (red RGB(255,0,0)is blue RGB(0,255,255), green is purple and blue is yellow). The screen is white and the text black. BLIT and gui calibration both work OK.
@matherp ,Peter is there any chance of adding an option to the ST7789_320 driver to cater for this version?
Tony
Posted: 02:52pm 03 Apr 2024
OPTION LCDPANEL anyspidisplay orientation, dcpin, resetpin, cspin [,backlightpin] [,INVERT]
set INVERT to invert the colours. Works on ILI9488 but may work on ST7789. Latest RC only
Edited 2024-04-04 01:39 by matherp
morgs67
Posted: 11:13pm 03 Apr 2024
@matherp
Using - PicoMite MMBasic Version 5.09.00RC3
Tested the following displays
INVERT
works on ILI9488
Does not work on-
ILI9341 or
ST7789_320
Footnote added 2024-04-04 09:38 by morgs67
link to item-
https://www.aliexpress.com/item/32960241206.html
Posted: 07:32am 04 Apr 2024
Try this
PicoMite.zip
morgs67
Posted: 10:29am 04 Apr 2024
@matherp Peter,
Tried your test invert, and success!
This works on-
ILI9488
ILI9341 and
ST7789_320
confirmed on each by trying normal and invert.
Tony
